Hello there, i'm a bit new to this forum, it's been helping me alot, and this is my first post
I am planing to build a Silent Optimized computer, with an NZXT H440.
I chose a GTX 770, i was planning to buy from Gigabyte with a non reference cooler.
Then it hit me.. i've been reading some reviews that the H440 does not have a good air flow.
with raises me the question
Should i buy a reference design or stick with Gigabyte's?
Which one will be the quietest in a NZXT H440?
note: i live in a tropical area
https://linustechtips.com/topic/159851-gtx-770-reference-vs-non-reference/
Still get the gigabyte if want quietness. The airflow can't be that bad, doesn't it have like 8 fans? just make sure to have fans in the roof of the case.
Corsair 400C- Intel i7 6700- Gigabyte Gaming 6- GTX 1080 Founders Ed. - Intel 530 120GB + 2xWD 1TB + Adata 610 256GB- 16GB 2400MHz G.Skill- Evga G2 650 PSU- Corsair H110- ASUS PB278Q- Dell u2412m- Logitech G710+ - Logitech g700 - Sennheiser PC350 SE/598se
Is it just me or is Grammar slowly becoming extinct on LTT?
Should the fans be taking air in or out of the case?
should have an equal or lose to equal number doing the pulling and pushing out
Non Reference cooler for a near silent pc.
Reference coolers are louder as they have to work hard at pushing the air over the GPU and out the back off the computer though a small vent.
Win 10 Pro 64bit| Intel i5-4670k| Corsair H100i| ASUS Maximus VI GENE| 2x8GB PC3-14900 Corsair Vengeance Pro Red| MSI GeForce GTX 1070 | SanDisk 240GB Extreme Pro SSD| WD 3TB Red | WD Black 3tb | Corsair Obsidian 350D| Corsair AX760 | Dust |
I personally like to have more air being feed into the case than being pushed out the case. (so 3 fan in to 2 fans out for example).
This helps feed nice cool air into the pc and if you using dust filters then it will also stop dust building up in the computer too.
But saying all that; As long as the is air passing through the computer then you should be ok :)
