Hi all
All of a sudden when playing games my pc now resets itself without a bsod, just switches off and immediately reboots. Have had the system for around 6 months and no problems till now. Ideas?
I4770
MSI GTX780TI
Corsair GS700 psu
MSI G43 gaming Mobo
I've heard could be power supply amongst other things.. Really hope it's not the Gpu.
Help needed please.
https://linustechtips.com/topic/159793-system-randomly-restarts-when-playing-games/
What game is it?
Do you have the blue screen codes?
I destroy my enemies when I make them my friends.
~Abraham Lincoln
In times when we are on the brink of destruction, war, and loosing ourselves, let's remember a basic fundamental element of love, forgiveness, and understanding; God bless!
Typically if a thermal shutdown, it will stay off for at least a few minutes. Load up HWMonitor and keep an eye on the temps. If they look ok, then most likely a bad PSU or the power controller on your mobo is flaky. You will need another PSU of course to test.
Forum Links - Community Standards, Privacy Policy, FAQ, Features Suggestions, Bug and Issues.
Folding/Boinc Info - Check out the Folding and Boinc Section, read the Folding Install thread and the Folding FAQ. Info on Boinc is here. Don't forget to join team 223518. Check out other users Folding Rigs for ideas. Don't forget to follow the @LTTCompute for updates and other random posts about the various teams.
Follow me on Twitter for updates @Whaler_99
Is it overclocked? It could be your temperatures so start monitoring them, could be some windows conflict but that is less likely because it only BSOD's under pressure as you described it, power supply may be also at fault and ram sticks.
