280x
Specs
https://linustechtips.com/topic/159770-help-me-to-choose/#findComment-2128290
Hows it better than the 770? I just want to know hows one better than the oder.
more vram so better in watchdogs, errmm i have one :P
My Setup :P
Skylake: I7-6700|MSI B150 GAMING M3|16GB GSKILL RIPJAWS V|R9 280X (WILL BE 1070)|CRUCIAL MX300 + WD BLACK 1TB
https://linustechtips.com/topic/159770-help-me-to-choose/#findComment-2128298
280 and 770 are equal but the boost with the 280x is better
Specs
https://linustechtips.com/topic/159770-help-me-to-choose/#findComment-2128305
Yeah, 3gb is great but isnt it more difficult to record with mantle?(wanna play tons of bf4) :D As I see the performance of the cards is very close.
well i cant tell you about bf4 cos something in my pc dont like it, and i get bad fps
My Setup :P
https://linustechtips.com/topic/159770-help-me-to-choose/#findComment-2128315
Where I live I can get booth for kinda the same price.
770 then. Shadoplay makes recording easy and it is faster.
https://linustechtips.com/topic/159770-help-me-to-choose/#findComment-2128325
I'd take the Nvidia card because it has better features.
That's very subjective. Most of the features on nvidia cards aren't implemented in games properly because they are proprietary. This means developers have to make their game compatible with AMD too, ultimately not using things like PhysX to their full ability. The only features that work well are shadow play and streaming to shield devices.
CPU: 5930K @ 4.5GHz | GPU: Zotac GTX 980Ti AMP! Extreme edition @ 1503MHz/7400MHz | RAM: 16GB Corsair Dom Plat @ 2667MHz CAS 13 | Motherboard: Asus X99 Sabertooth | Boot Drive: 400GB Intel 750 Series NVMe SSD | PSU: Corsair HX1000i | Monitor: Dell U2713HM 1440p monitor
https://linustechtips.com/topic/159770-help-me-to-choose/#findComment-2128346
Thats a shame. :( But I think the 280x will be the one for me cause 3gb vram is better for future games.
other games are fine
My Setup :P
https://linustechtips.com/topic/159770-help-me-to-choose/#findComment-2128351
CPUIntel 4670k  Motherboard - Gigabyte GA-Z87X-D3H  RAMKingston HyperX 8GB  GPU - EVGA 780  Case - Fractal Design Define R4    Storage - 2TB WD Black, Samsung 840 Evo 128GB     PSU - Corsair RM650  Display -  Benq XL2430T and Acer S235HL  Cooling - CM Hyper 212 Evo  Keyboard - Corsair K95  Mouse - Razer Deathadder  Sound - Sennheiser HD 558                                 Mic - Blue Snowball  Phone- OnePlus One  Tablet - Nvidia Shield
https://linustechtips.com/topic/159770-help-me-to-choose/#findComment-2128387
r9 280x. It is cheaper currently (in the US) and can be overclocked to outperform the GTX 770 in pretty much any game. It also has 3gb of vram, which will outperform the GTX 770's 2gb at 1440p.
Thing is I dont need more than 1080p, and as far as I know 2gb+ VRAM only makes sense above that.The price difference is around 15-20$ so its not a mayor problem.
https://linustechtips.com/topic/159770-help-me-to-choose/#findComment-2128945
Well then I may lean towards the GTX 770. Nvidia seems to always be a bit quicker on releasing new drivers for games, and they have Shadowplay, and integrated streaming with Twitch. The GeForce Experience is really underrated as well for quickly optimizing a game if you don't want to worry about tweaking settings.
I should be studying.
https://linustechtips.com/topic/159770-help-me-to-choose/#findComment-2128989
