$20 water cooling
Go to solution Solved by decidedlydead,
I use am4. Ryzen 5 PRO 1500
You won't be going water cooling with $20. What cpu do you have? What is the cooler height limit of your case?
In pursuit of knowledge and mistakes.
Please quote or @ me if you want me to be notified. Mark replies as answers if they solved your problem.
Folding at Home BOINC
https://linustechtips.com/topic/1597280-20-water-cooling/#findComment-16629679
No.
AMD R9 9900X | Thermalright FW Pro Black, 3x TL-B12E | Asus Strix X670E -F | 64GB G.Skill 6000C26
Zotac 4070 Ti Trinity OC | WD SN850, SN850X, 2x SN770 | Seasonic Vertex GX-1000 | ProArt PA602
Adcom GFP-345, Adcom GFA-555, S.M.S.L D1+PS100, Cerwin-Vega! CLSC-15, Monster HDP-1800
https://linustechtips.com/topic/1597280-20-water-cooling/#findComment-16629683
What chip?
Even with the classic external car rad aquarium pump loop 20$ is quite the stretch, i mean you could buy used maybe even scrap ones if available but thatll be alot more effort than its worth compared to buying a new one imo, though apparently you can also use heater cores for this and thats probably more viable to buy used/scrap if available
Aquarium pumps wise gonna need something with decent h max and the 107 or something aquarium pump i once tried with this kinda setup seems to be able to do it albiet at 10$, again maybe a used/scrap one
Res you can probably use a bucket or something like that and tubes wise even a garden hose will work though good luck diying the fittings/adapters, did mine with bottlecaps and melted plastic which is a horrible way to do it but it worked
https://linustechtips.com/topic/1597280-20-water-cooling/#findComment-16629686
4 minutes ago, Somerandomtechyboi said:
What chip?
This reeks of 2004 and I love it.
ask me about my homelab
https://linustechtips.com/topic/1597280-20-water-cooling/#findComment-16629688
9 minutes ago, Somerandomtechyboi said:
What chip?
Even with the classic external car rad aquarium pump loop 20$ is quite the stretch, i mean you could buy used maybe even scrap ones if available but that'll be a lot more effort than its worth compared to buying a new one imo, though apparently you can also use heater cores for this and that's probably more viable to buy used/scrap if available
Aquarium pumps wise gonna need something with decent h max and the 107 or something aquarium pump i once tried with this kinda setup seems to be able to do it albeit at 10$, again maybe a used/scrap one
All just to be beaten by spending 10-15$ more on the dime a dozen dual tower heatpipe coolers thats out now in reliability and actual usability beyond the CPU and board you DIY it to. Also you forgot the block cost to bolt to the CPU.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
https://linustechtips.com/topic/1597280-20-water-cooling/#findComment-16629694
i was only born in 2007 and i just know about it cause some whacky watercooling experiment videos, basically the cheapest and best price/performance if you need a crapton of cooling capacity so basically completely useless unless you are running hedt or delidded chip
tried building one cause wolfdale e8000s kept running really hot but eventually figured out that this was a futile effort though the only thing that was really missing is the block and a bucket for the res
water is like that inbetweener between air and subzero where its better than air but nowhere near a chiller or a phase change loop and only useful if your cpu can even transfer its heat to the block and has a high heat output
considering the hassle and space one of these takes up id rather just go straight for a chiller loop or a phase change system instead cause atleast i get some decent temps out of it and besides its funnier to challenge and demolish old ln2 world records with just aircooling
water probably isnt going to let me push this thing any further than 3400 but put it under a chiller and -50c then maybe i can hit 3600+ with it and as far as i can tell none of the old ln2 records for 45nm even come close to this thing as they all seem to be below the 3200 mark
https://linustechtips.com/topic/1597280-20-water-cooling/#findComment-16629695
block yeah thats gonna take quite some luck, without a decent block the setup is completely useless and will definitely fall flat on its face even compared to a 35$ phantom spirit 120
with a decent block and a car rad itll blow the phantom spirit out ofnthe water but probably not at 20$ unless you get really lucky with deals on used stuff or maybe salvage an aio block from a broken aio which should also work if you cant find someone selling an actual waterblock at a decent price and mounting hardware shouldnt be an issue if unavailable cause zipties exist and these blocks are pretty lightweight unlike a tower cooler
and i also forgot about used aios some of them are going dirt cheap these days but perf is probably not gonna go beyond the ps120 perf wise cause old aio, probably will still beat the 20$ assassin king or burst assassin though
https://linustechtips.com/topic/1597280-20-water-cooling/#findComment-16629697
I won my class in Forum Warz with an air cooled E8600 ES, using an Ultra 120 Extreme 😄
563x8.5 iirc in the disgusting summer heat with no AC. Was like 30-35c in my house, had a box fan right next to my Stacker lol
Good times.
https://linustechtips.com/topic/1597280-20-water-cooling/#findComment-16629706
You could probably find a 6 dollar air cooler from AliExpress or something and be fine.
https://linustechtips.com/topic/1597280-20-water-cooling/#findComment-16630021
Thats ancient and nowhere near powerful, maybe if you were talking a 4.8ghz+ x58/79/99 chip as those output tons of heat
Just put some cheap tower cooler on it and call it done, if you never want to upgrade the cooler again just put a phantom spirit 120 on it and you wont need to replace it for future cpus whenever you decide to upgrade to the much faster 5700x3d or even the 9800x3d
https://linustechtips.com/topic/1597280-20-water-cooling/#findComment-16630587
