Need help on gpu, no display
Solved by Mikeeeyyyy_,
16 hours ago, ki8aras said:
as i understand it, popping the 1650 back in made the computer work again, so it was either a bad contact when you installed the 3060, or the 3060 has a problem. try popping it back in and if it doesnt work then maybe try it on a friend's computer
Sorry for the late reply. I tried the 3060 to a friend's computer, still no display. Both of us came to the conclusion that the 3060 is faulty. Thanks for the suggestion!
