Amd A6-3500 Apu
F1A75-I DELUXE MOTHERBOARD
8Gb kingston hyper x ram
Eva Gtx 660 gpu
650 watt gold power supply
I want to overclock the apu cause it sucks balls right now :) I cant get youtube on my home wifi,  so can anyone help me or point me in the direction a guide. Dont really want to do bios necesarily, kinda just wanna slide a bar lol... Also should i overclock ram??? If so how???
Its all looks these days
https://linustechtips.com/topic/159589-apu-overclock-help/
Please don't re-post.. With that said do you have a stock heatsink or are you using oem. That will determine how far you can go with the oc.
CPU: i7-4770k @4.8ghz---Motherboard: Asus Sabertooth z97---Ram 32gb Corsair Vengeance---GPU: 2 EVGA GTX 980 4gb way sli---Case: Corsair 600T White---Storage: 500gb 850 Pro & WD Black 4tb---PSU: Corsair RM1000
https://linustechtips.com/topic/159589-apu-overclock-help/#findComment-2126091
I think stock.....
https://linustechtips.com/topic/159589-apu-overclock-help/#findComment-2126100
Fiddle with settings in the BIOS that is the best way.
But actual guides help too.
https://linustechtips.com/topic/159589-apu-overclock-help/#findComment-2126115
The thing is those APU"s are really heat picky and aren't really happy when your running over 60c, they tend to throttle down at that point. The first thing I would recommend is to get an after market heatsink, that way you will run into less problems. If it gets to hot at the start the screen will just remain black and maybe beep.
https://linustechtips.com/topic/159589-apu-overclock-help/#findComment-2126116
you have to go through the bios to OC your APU mate, it involves Overvoltage, unlocking some stuff and ampping the Clock Speed
 Crust : Intel Core i5 4690K @ 4.4Ghz 1.45v  |  MotherboardMSI Z97 MPower  |  Fruity FillingMSI GTX 960 Armor 2Way-SLI |  CoolingNoctua NH-D15  |  RAM : 16GB Corsair Vengeance 1600Mhz | Storage : 2xSamsung 840 EVO 500GB SSDs Raid-0  |  Power Supply : Seasonic X-Series 1250W 80+Gold  |  Monitor : Dell U2713HM 27" 60Hz 1440p  |
https://linustechtips.com/topic/159589-apu-overclock-help/#findComment-2126137
My apu is only at 43c
Ok is there a guide, or can you tell me how :) if I fry the cpu, will that damage my system???
https://linustechtips.com/topic/159589-apu-overclock-help/#findComment-2126147
Dowload MSI Control center, uses bios , but is not actualy in bios
https://linustechtips.com/topic/159589-apu-overclock-help/#findComment-2126156
what @spwath said should be better and less complicated than the Bios
https://linustechtips.com/topic/159589-apu-overclock-help/#findComment-2126166
Yeah, nice and easy, Im using it right now, so far my OC is going well, but just started around 30 min to an hour ago.
https://linustechtips.com/topic/159589-apu-overclock-help/#findComment-2126170
CPUs take a beating to get 'fried'
https://linustechtips.com/topic/159589-apu-overclock-help/#findComment-2126195
So just use that :) what is a good voltage, frequency, speed exc....
I have it at a boost clock of 2.4 ghz, what should I take it too?? also can I unlock a core???
https://linustechtips.com/topic/159589-apu-overclock-help/#findComment-2126206
i'd say some where around 1.0V for 3.6~3.7Ghz
you can unlock em all, damn it, that's why your APU suck, it's running on only two cores, isn't it ?
https://linustechtips.com/topic/159589-apu-overclock-help/#findComment-2126221
4.0 ghz with a stock cooler! Are you sure??? that seems a little crazy
oh, crap; t all mate than, till you  get some decent cooling bro, with the Stock !!!  you'll burn the shit out of it, i thought you had some good cooling going on !
https://linustechtips.com/topic/159589-apu-overclock-help/#findComment-2126244
haha thats what I was wondering??? I am going to get an h100 off my friend for 30$
what I am doing right now lol
idle or load O.o?
https://linustechtips.com/topic/159589-apu-overclock-help/#findComment-2126269
then you can think about squizing some more out of it !
Run prime 95, check temps when running and tell us how hot... you don't want to fry your cpu when you run games...
he's using the Stock cooler, he'll fry it the moment he hits apply
https://linustechtips.com/topic/159589-apu-overclock-help/#findComment-2126283
Run prime 95 (If you don't know how to use it just run 7zip benchmark using all cores and memory xD), check temps when running and tell us how hot... you don't want to fry your cpu when you run games...
my cpu after playing battlefield 3 on ultra is 52c
https://linustechtips.com/topic/159589-apu-overclock-help/#findComment-2126322
After... when opening a program when you closed the game the CPU may have lost 10-25 ºC :P
is that bad lol???
If I get an i5 2400 not k... can I overclock that even though it is not a k chip???
https://linustechtips.com/topic/159589-apu-overclock-help/#findComment-2126343
as I said, after closing...
in 5 secs it can lose 15ºC easily bc fan is at max. rev and cpu isn't emitting THAT amount of heat anymore...
I doubt that when it's at 43 ºc idle it'd be 53ºc under full load :/
(LÅL dunno if you understand me)
OHHHHHH I be gettin what you be layin down now :)
https://linustechtips.com/topic/159589-apu-overclock-help/#findComment-2126405
Nope, only unlocked K series can be Overclocked
https://linustechtips.com/topic/159589-apu-overclock-help/#findComment-2128323
