URGENT HELP NEEDED
Solved by TetraSky,
to add to what Mariushm said... Before doing all that, test you main power socket to see if there's even power coming from the electrical panel to this plug. It's possible there was too big a load on circuit and the protection tripped (like, if this circuit is shared with other plugs and someone plugged a air dryer or heater or something that consumes a lot of watts)
Plug a lamp or something in the same socket the PC was plugged in and see if it works.
If it does, problem is likely the computer's PSU. If it does not, check your electrical panel for a tripped switch.
