Budget (including currency): ~1500€
Country: CZE
Games, programs or workloads that it will be used for: games, maybe some video editing
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): https://de.pcpartpicker.com/list/nd48Qd
I just need to know if those parts especially the cooler are good choices. I would even consider going for 1440p if someone knows some good budget monitors on at least 165hz. Also I can't to find anywhere the supported ram for the mobo I chose so if anyone could tell me if the g.skill flare x5 is compatible and stable with the msi b650m gaming plus wifi. Thanks for your time! 🙂
https://linustechtips.com/topic/1594683-help-with-my-build/
Country: CZE
G.Skill product pages have a motherboard QVL tab. See https://www.gskill.com/qvl/165/396/1673491242/F5-6000J3038F16GX2-FX5-QVL.
The case does not support the USB-C front panel header on the motherboard.
https://linustechtips.com/topic/1594683-help-with-my-build/#findComment-16612091
Okay thanks. What case should i get? Or maybe even a different motherboard?
https://linustechtips.com/topic/1594683-help-with-my-build/#findComment-16612116
If you don't care about a front panel USB-C port, you cann keep the current case.
All but the most inexpensive AM5 motherboards have the Type-E connector to support front panel USB-C.
Cases you might consider:
https://de.pcpartpicker.com/product/6VXV3C/deepcool-ch360-digital-microatx-mid-tower-case-r-ch360-bkape3d-g-1
https://de.pcpartpicker.com/products/case/#t=5,7,6&B=6,3,4&D=16,4,8&sort=price&page=1
https://de.pcpartpicker.com/product/FG7scf/lian-li-a3-matx-microatx-mini-tower-case-a3-matx-wd-black
https://de.pcpartpicker.com/product/CjFmP6/lian-li-a3-matx-microatx-mini-tower-case-a3-matx-x
https://de.pcpartpicker.com/product/fPZ9TW/asus-prime-ap201-microatx-mini-tower-case-ap201blkmesh
https://linustechtips.com/topic/1594683-help-with-my-build/#findComment-16612180
Five pipe cpu cooler.
https://www.eurogamer.net/digitalfoundry-2023-amd-ryzen-5-7500f-review
PCPartPicker Part List
CPU: *AMD Ryzen 5 7500F 3.7 GHz 6-Core OEM/Tray Processor  (€153.69 @ Caseking)
CPU Cooler: *Deepcool AG500 BK ARGB 67.88 CFM CPU Cooler  (€44.90 @ Galaxus)
Motherboard: *ASRock A620M Pro RS WiFi Micro ATX AM5 Motherboard  (€135.89 @ Caseking)
Memory: *TEAMGROUP T-Create Expert 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (€99.89 @ Galaxus)
Storage: Western Digital Black SN770 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (€111.00 @ Amazon Deutschland)
Video Card: *Sapphire PULSE Radeon RX 7800 XT 16 GB Video Card  (€502.79 @ Galaxus)
Case: Montech AIR 100 ARGB MicroATX Mid Tower Case  (€64.90 @ Proshop)
Power Supply: *Corsair RM750e (2023) 750 W 80+ Gold Certified Fully Modular ATX Power Supply  (€98.90 @ Amazon Deutschland)
Monitor: *AOC 24G4XE 24.0" 1920 x 1080 180 Hz Monitor  (€119.00 @ Amazon Deutschland)
Total: €1330.96
Generated by PCPartPicker 2025-01-01 21:50 CET+0100
https://linustechtips.com/topic/1594683-help-with-my-build/#findComment-16612183
If I want upgradeability should I get the ASRock B650M Pro RS? I feel it would be better for future upgrades. Keep in mind I'm fairly new to knowing which is better etc. but based on my research I found that the b650m would be better for the future. Thanks for your time! 🙂
https://linustechtips.com/topic/1594683-help-with-my-build/#findComment-16612238
The ASRock B650M Pro RS has better VRM's than the board I posted.
https://linustechtips.com/topic/1594683-help-with-my-build/#findComment-16612247
