Heeey guys,
I would love it if someone can help me with this because it is driving me crazy.
I am running 3 sticks of Corsair LPX 8Gb 3200Mhz for a total of 24GB. However, for some reason, Xmp does not work.
When saving and exiting from the bios, it does the memory training reboot thingy for three times before it boots normally (at 2133mhz).
I suspect (but I am not a pro) that this is causes by my CPU, R5 2600x, which is notorious for not having the best memory controllers.
I learned that I can up the Soc, mem controler, and some other voltages in the bios, but idk by how much + these acronyms (see pic 3) confused the hell out of me.
Please help.
image.png.bbc096c6a1575bbf6a04075b195a7a2a.pngimage.thumb.jpeg.0c5c8d97402fed64e0e1df3408f1a4ea.jpegimage.thumb.jpeg.76745075cd64e8821fe1b7ea633c51d7.jpeg
https://linustechtips.com/topic/1594168-xmp-just-does-not-work/
I have 3 sets of Corsair DDR2.. and none of them will boot with each other.
Maybe clear your CMOS and try again, but if it doesn't work, its not going to run with XMP.
AMD R9 9900X | Thermalright FW Pro Black, 3x TL-B12E | Asus Strix X670E -F | 64GB G.Skill 6000C26
Zotac 4070 Ti Trinity OC | WD SN850, SN850X, 2x SN770 | Seasonic Vertex GX-1000 | ProArt PA602
Adcom GFP-345, Adcom GFA-555, S.M.S.L D1+PS100, Cerwin-Vega! CLSC-15, Monster HDP-1800
https://linustechtips.com/topic/1594168-xmp-just-does-not-work/#findComment-16608607
have tried that multiple times, but to no avail.
And these are DDR4, and they work perfectly fine together, just not with the XMP.
To Add, I cant even manage to run 1 stick with XMP!
https://linustechtips.com/topic/1594168-xmp-just-does-not-work/#findComment-16608620
With the R5 2600 the most you can probably do is 3000 or 2933 with 2 sticks and 2666 to 2933 with more.
Try loading XMP (DOCP) and decreasing the frequency manually. 2666 should be stable.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
https://linustechtips.com/topic/1594168-xmp-just-does-not-work/#findComment-16608637
Early Ryzen Memory controllers were problematic at high speeds, and add 2 dimms to a single channel put much more load on it. Zen+ is better but still nowhere near as good as Zen3. If you want higher ram speeds and better cpu performance, an R5 5600X or non-x would be a massive upgrade that your motherboard (even alot of 300-series) would most likely support and they are dirt cheap. Best drop in upgrade i have ever done.
https://linustechtips.com/topic/1594168-xmp-just-does-not-work/#findComment-16608656
