1 minute ago, B3RL1N8 said:
Asus ROG Strix B550-F
Is gonna be able to work with the cpu: Ryzen 9 5900x
Yes
Refresh before you reply
https://linustechtips.com/topic/1592915-i-need-help/#findComment-16600880
2 hours ago, B3RL1N8 said:
basically just getting whole new motherboard and new cpu just want to make sure these are compatible.
lemme guess chatgpt reccomendation?
that hardware is straight outta 2021 and youd be better off with zen4 on a 7900(x) with a b650 which will perform better and not be on a dead platform
if you just game the 78/9800x3d will be a much faster chip but if those are too expensive you can settle for a 7600 or 7700
https://linustechtips.com/topic/1592915-i-need-help/#findComment-16600939
