Problem: Despite modifying Memory DPM States and associated voltages, the GPU:
  • Cause: Likely due to AMD drivers enforcing strict idle power limits or BIOS locks.? What do you think?
Key Observations:
  • Idle: GPU Clock ~8-30 MHz, Memory Clock ~192 MHz, Power Consumption ~12W.
  • My aim [when idle]: GPU Clock ~8-30 MHz, Memory Clock ~1990 MHz, Power Consumption ~49W
Things i have done:
r/overclocking - Stabilize idle GPU and memory clocks - Help
Left all in default in the AMD Adrenaline (may overlap, so put it in default for now?)
Also did this in the Power Plan Windows:
Set to High Performance Mode.
  • Adjusted Processor Power Management:
    • Minimum Processor State: 100%.
    • Maximum Processor State: 100%.
  • Turned off PCI Express Link State Power Management.
https://linustechtips.com/topic/1592661-stabilize-idle-gpu-and-memory-clocks-help/
Lets start with simple question, why? and what for? What are you trying to achieve ? Why would you want high memory clocks while idle ?
R7 9800X3D, Arctic Liquid Freezer III 360 ARGB, ASRock X870E TAICHI, Kingston FURY 64GB (2x32GB) 6000MT/s CL30 Beast Black RGB , Gigabyte RTX 4090 Gaming OC, Windows 11
Download a distributed computing program and let it run in the background, it will keep your clocks high all the time.
If you want a suggestion, BOINC is the most customizable one. Attach to Primegrid and select GFN16 as your subproject of choice.
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
Because i have coil whine GPU, and i understand that if im seeing an youtube video it stops complety! I tried to underclock it, but now has a constant noise but whenever im viewing like a youtube video the PC stays dead silent no coil no nothing only the fans
Ohh that's a great work around, just one more questions is it ok to keep my pc like this, or will it short the lifespan?
Yeah, it'll be fine. As long as temps are okay, you can run at 100% 24/7 and there won't be a problem.
3 minutes ago, castellbranco said:
One more question should i put my MorePowerTool changes to default?
That's a good idea, yes.
It will shorten the lifespan, but most computers these days are gonna outlive their own usefulness
13 hours ago, castellbranco said:
Hey man i forgot to tell that i got an AMD GPU does this still work? the GFN16 just because i already pdated and still no work why?
Sorry for the delay, are you still having issues or has it sorted itself out?
Either way, it surely works for AMD, yes. And it's never an issue on the project side, it simply does not run out of work. It's something that's not setup correctly on your end.
On your account, go your Computers and check the location on that machine
Then back to the preferences page, click Switch View, then make sure you've set up the preferences for the correct location
After that, go back to the boinc client and manually update the project so that it talks to the server and gets updated preferences.
