What psu are you using?
https://linustechtips.com/topic/1591886-rtx-3090-power-cables/#findComment-16593603
4 minutes ago, Spreewald said:
The cheapest and easiest solution is probably sleeved extensions. These can allow for 3x individual 8pin cables which look pretty clean.
If you want a unified 3x 8pin connector, a custom cable or extension will do that but isn't as easy to reuse in case you change gpus.
Where are you shopping / located?
https://linustechtips.com/topic/1591886-rtx-3090-power-cables/#findComment-16593609
I'm in the US. I'm free to getting something from online that will look good, but not blow up my GPU.
https://linustechtips.com/topic/1591886-rtx-3090-power-cables/#findComment-16593612
This kit works: https://www.amazon.com/AsiaHorse-Sleeved-Extension-Connector-Combs-White/dp/B0B56LHGRC
It's not a single cable but you line them up straight like this:
https://linustechtips.com/topic/1591886-rtx-3090-power-cables/#findComment-16593639
  Reveal hidden contents
Yes! Thats exactly what I'm looking for. Sorry for the confusing😅. Thank you so much, have a nice day or night!
https://linustechtips.com/topic/1591886-rtx-3090-power-cables/#findComment-16593641
Just to clarify, I would use the 24 pin correct?
https://linustechtips.com/topic/1591886-rtx-3090-power-cables/#findComment-16593645
No, you would use the 3x 6+2 cables. You can line them up like in the photo for your gpu.
https://linustechtips.com/topic/1591886-rtx-3090-power-cables/#findComment-16593655
I would stop using that piggy back connector and run a fresh line, bundle them with a ziptie if you have to.
AMD R9 9900X | Thermalright FW Pro Black, 3x TL-B12E | Asus Strix X670E -F | 64GB G.Skill 6000C26
Zotac 4070 Ti Trinity OC | WD SN850, SN850X, 2x SN770 | Seasonic Vertex GX-1000 | ProArt PA602
Adcom GFP-345, Adcom GFA-555, S.M.S.L D1+PS100, Cerwin-Vega! CLSC-15, Monster HDP-1800
https://linustechtips.com/topic/1591886-rtx-3090-power-cables/#findComment-16593663
