Need help for picking a Graphics Card
Go to solution Solved by podkall,
https://www.techpowerup.com/gpu-specs/radeon-rx-7700-xt.c3911
https://www.techpowerup.com/gpu-specs/radeon-rx-6800.c3713
They're quite similar, 6800 bit more rich in hardware 7700 XT bit more better because of newer architecture comparatively,
They are even on average basically, but the slight or moderate advantage of either will depend on what game and settings you use.
Budget (including currency): 4000AED
Country: United Arab Emirates
Games, programs or workloads that it will be used for: Competitive games and Triple A games at 1440p
I'm planning to pick a Graphics Card for my first build. I have  4000AED (1,089USD) budget. My choices are RX 6800 and RX 7700XT. My problem is that I cant really pick. Do I wait for the new GPU's to come out?, I don't edit or do work related just games but at the same time the new GPU's are coming out so the 6800 will be 2 generations older now. I know the 6800 will have more VRAM and games these days does require more VRAM. So please help
https://linustechtips.com/topic/1590826-need-help-for-picking-a-graphics-card/
You could wait if you want,
6800 isn't bad, especially thanks to the extra VRAM it has, not that more means better it just means it's less likely to run out of it..
  • Any ongoing discounts on either cards or not really?
current PC:
PC configs I used before:
current PC:
Yeah, I would get the 6800 because of the VRAM, slight performance increase, and price. You could also wait for new gpus...
Make sure to mark solutions, as it helps us find people who need help faster. Thanks!
I am human and am therefore prone to error, so I apologize if I make mistakes and I hope you understand.
Have a Nice Day!
