Hi everyone. I need a good lying case. In size and specs similar to Phantom 410 which I own now. If any of you know of cuch case please help.
Specs:
PC:CASE: FD Define r6 | CPU:Intel Core i7-8700k | MB: MSI z370 PC Pro RAM: 32GB Corsair vengance LPX 3000 GPU: Asus rx 6900xt Tuf STORAGE: nand 500GB Samsung 970Evo plus ; Game Storage: 2TB Samsung 860QVO Storage: 2 x WD Green 4TB | PSU: Corsair RM850x | CPUCooler: Noctua NH-D15   DISPLAY: LG 27GL850
https://linustechtips.com/topic/158885-i-need-a-lying-case/
If you're talking about cases that lay horizontally, like the archaic HP's, Dells and IBM's, I think you're out of luck unless you can find an OEM Dell case and mod it. Or get a cube case.
The problem with the horizontal cases is they have horrible air flow. Unless you have a Dremel and are creative, your components will run very hot, if at all.
"Energy drinks don't make my mouth taste like yak buttholes like coffee does, so I'll stick with them." - Yoinkerman
https://linustechtips.com/topic/158885-i-need-a-lying-case/#findComment-2117281
Thanks everyone. I do however intend to build a table and integrate my PC inside but that s not gonna happen any time soon :/
Specs:
https://linustechtips.com/topic/158885-i-need-a-lying-case/#findComment-2117325
