1 hour ago, heradzsd said:
You think i should to for a better Card my budget is 500 Euro
You think i should to for a better Card my budget is 500 euros
What's the rest of your system? If it's from the 1660 era and the budget range, the CPU might bottleneck a new card.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
https://linustechtips.com/topic/1586866-upgrade-help/#findComment-16555956
38 minutes ago, Salted Spinach said:
Good but will be quite bottlenecked by the 10700 at least at 1080p
https://linustechtips.com/topic/1586866-upgrade-help/#findComment-16555977
2 hours ago, heradzsd said:
The name is xilence i am not sure about the model
Can you take picture of the PSU's name in the PC if you have access to it?
Also 7800 XT if the PSU only has 1 8pin, then the only options are,
6650 XT
https://pcpartpicker.com/product/Yy6p99/xfx-radeon-rx-6650-xt-8-gb-speedster-swft-210-core-video-card-rx-665x8dfdr
RTX 4060
https://pcpartpicker.com/product/7s88TW/msi-ventus-2x-black-oc-geforce-rtx-4060-8-gb-video-card-rtx-4060-ventus-2x-black-8g-oc
7600 XT
https://pcpartpicker.com/product/Cj7scf/asus-dual-oc-radeon-rx-7600-xt-16-gb-video-card-dual-rx7600xt-o16g
or 4070
https://pcpartpicker.com/product/JW3NnQ/pny-xlr8-gaming-verto-epic-x-rgb-geforce-rtx-4070-12-gb-video-card-vcg407012tfxxpb1
Where U from, Germany?
current PC:
PC configs I used before:
https://linustechtips.com/topic/1586866-upgrade-help/#findComment-16555985
Xilence is the budget brand of Listan, the same company that owns be quiet!. The quality of Xilence ends where be quiet! starts. So it's very low end and I wouldn't trust any recent GPU to it.
https://linustechtips.com/topic/1586866-upgrade-help/#findComment-16556133
