Budget : 1000 GBP
Country: UK
Games, programs or workloads that it will be used for: GTA V, RDR2, Mafia, Fortnite, streaming
Other details : Reusing RTX 3060 from current build along with 32gb vengeance ram. Current part list https://uk.pcpartpicker.com/list/ztNQ89
https://linustechtips.com/topic/1583466-building-a-pc-and-need-feedback/
2 minutes ago, Archilux said:
Budget : 1000 GBP
Country: UK
You are definitely overspending on the Cooler, paste and PSU.
https://uk.pcpartpicker.com/list/dgKBsh
Does the CPU come with paste? I assumed not so got some just in case also does the case come with fans?
the CPU cooler will come with paste 🙂
The NZXT H9 Flow will come with 4x 120mm case fans.
The NZXT H9 Flow is an expensive case and you could save quite a bit of money there too.
The cooler usually comes with paste, or its pre-applied.
I am writing to you... from SPACE!  I live in the middle of nowhere Northern California, and have Starlink.
CPU: Intel Core i9 9900KF
Motherboard: ASRock Z390 Taichi Ultimate (My PC can kick your PC's ass, apparently... According to Lyle...)
Memory: Corsair Vengeance LPX 64GB (4 X 16GB) DDR4 3600 C18
GPU: GeForce RTX 3080 Ti (Acquired from the Newegg Raffle program)
Storage: Samsung 970 PRO 1TB (Boot), Samsung 970 EVO Plus 1TB, Samsung 860 PRO 1TB, WD Gold 10TB
Case: CM Trooper SE
Just now, Archilux said:
Thank you for all your help, has made this a lot cheaper.
No Problem 🙂
The Thermalright Peerless Assassin 120 is plenty enough for the CPU you picked and will come with a tube of thermal paste.
The MSI PSU also comes with 10 year warranty.
