you have a printer with a bed level function. what slicer do you use?
there should be an option in most slicers to add a line of code. There should be options to modify your printer settings, and in those settings or text box add the lines:
G29
M420 S1
basically they level and save the bed leveling settings to your machine. I'd recommend running the Gcode at every print if you have a removable build plate.
Rotate it by 180° and test again.
Other side doesn't stick -> clean the PEI sheets with soap and water
same side doesn't stick -> bed leveling
The Declaration of Independence, once the charter of democracy, begins by saying that certain things are self-evident. If we were to trace the history of the American mind from Thomas Jefferson to William James, we should find that fewer and fewer things were self-evident, until at last hardly anything is self-evident. (G. K. Chesterton - Aug. 14 1926 (The Illustrated London News))
14 hours ago, Nov845 said:
I have an Ender 3 V2, and I installed a 2nd Z Axis Motor. I think I got the Z offset correctly calibrated, but the right side isn't sticking. I've done the auto leveling a couple times, but do I need to do a manual leveling? Or could something else be the issue?
First tram the bed, then heat up the bed and wait until its fully heated. You can enable bed leveling mesh with M420 S1 in your start gcode after G28 (home). You don't need to run G29 each time (unless you want to). Might be useful if your bed is changing a alot or you're doing long prints. I would tram the bed before using the printer every time.
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
G29
M420 S1
I use Cura
