Hi guys ,I upgraded my pc from Ryzen 3600x and Nvidia 1050ti to Ryzen 5800x and Nvidia3070. My main game is cs2. I used to get 150fps in Anubis(all low) but after I upgraded my pc I got 190 fps in Anubis (all low).Is this normal ? I think I should get more fps. Pls help
This is my pc before upgrade:
Gigabyte B450M S2H
16gb ram
Gtx 1050ti
Ryzen 3600x
3fans
1tb ssd windows
1tb ssd storage
After upgrade
Gigabyte B450M S2H
16gb ram
Rtx 3070
Ryzen 5800x
3fans
1tb ssd windows
1tb ssd storage
https://linustechtips.com/topic/1582588-low-fps-after-upgrading-pc/
Have you tried any of the following things:
- Clear all temporary files through Disk Clean-Up?
- Ensured Windows has all up-to-date drivers?
- Cleanly reinstall GPU drivers?
- Ran "sfc /scannow" in Command Prompt with Administrator to check system integrity?
- Checked how the CPU/GPU is behaving in Task Manager during gameplay?
- Checked temps when under pressure?
I know the performance gap between a 3070 and a 1050 Ti is large, and that something is up.
Don't tell me to upgrade. I would've done so if I could.
Just now, phanto_m said:
There is a bunch of unwanted files in disk I cleaned it up
and this is the info in task manager after the clean up and the drivers are up to date i have cleaned reinstalled gpu driver
I was running a bench mark map on cs2 and tabbed out
is it correct to test this way?
this is the result i got from the cs work shop map bench mark
[VProf]
[VProf] -- Performance report --
[VProf] Summary of 39399 frames.  (3226 frames excluded from analysis.)
[VProf] FPS: Avg=344.4, P1=126.0
[VProf]
[VProf]                                                       All frames         Active frames
[VProf]                                                         Avg    P99        N    Avg    P99
[VProf] ---------------------------------------------------- ------ ------   ------ ------ ------
[VProf]                                           FrameTotal   2.90   7.94    39399   2.90   7.94
[VProf]                                     Client Rendering   1.56   2.76    39399   1.56   2.76
[VProf]                                       Frame Boundary   1.09   1.83    39399   1.09   1.83
[VProf]                                    Client Simulation   0.47   1.68    39399   0.47   1.68
[VProf]                                    Server Simulation   0.38   2.50     7311   2.03   2.87
[VProf]                                          Server Game   0.30   2.02     7311   1.59   2.37
[VProf]                                           Prediction   0.23   1.27    39399   0.23   1.27
[VProf]                                  Client Input/Output   0.17   0.92    39399   0.17   0.92
[VProf]                                           PanoramaUI   0.15   0.32    39399   0.15   0.32
[VProf]                                         UserCommands   0.14   0.98     7311   0.73   1.15
[VProf]                                                  HUD   0.12   0.26    39399   0.12   0.26
[VProf]                                          Unaccounted   0.10   0.41    39399   0.10   0.41
[VProf]                                     Server Animation   0.05   0.36     7311   0.26   0.42
[VProf]                               Server Send Networking   0.05   0.32     7311   0.26   0.37
[VProf]                                                 NPCs   0.05   0.45     7311   0.24   0.63
[VProf]                                           Networking   0.04   0.28     7314   0.21   0.38
[VProf]                                     Client_Animation   0.03   0.24     7311   0.19   0.29
[VProf]                                  Server PackEntities   0.03   0.23     7311   0.18   0.28
[VProf] LatchAndSaveLastSimulationValuesForInterpolationList   0.02   0.16     7311   0.13   0.19
[VProf]                                                Magic   0.00   0.00      330   0.23   0.69
[VProf]                                           FileSystem   0.00   0.00        4   0.28   0.93
[VProf]
[VProf]
i will jump in a match to test anubis out again cause i got avg 300 plus in bench mark map,might be server problems
