Recommend PC Build pls
Here is a build list for an AMD based system, until Intel fixes their Microcode issues I wouldn't bother with them. You'll want to get the best GPU you can afford to get even close to that 280hz refresh rate. You could, if you need it to be a little cheaper, go for a 4070 Super or a 7900GRE. I'd utilize the absolute maximum your budget allows though. Also side note, the 9000 series processors are dropping pretty much now so if you can wait for reviews there may be a better processor in the new series for you.
CPU: AMD Ryzen 5 7600X 4.7 GHz 6-Core Processor ($196.78 @ Amazon)
CPU Cooler: Thermalright Peerless Assassin 66.17 CFM CPU Cooler ($33.90 @ Amazon)
Motherboard: MSI B650 GAMING PLUS WIFI ATX AM5 Motherboard ($169.99 @ B&H)
Memory: TEAMGROUP T-Force Vulcan 32 GB (2 x 16 GB) DDR5-6400 CL32 Memory ($94.99 @ Amazon)
Storage: Crucial P3 Plus 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($117.99 @ Amazon)
Video Card: Sapphire PULSE Radeon RX 7900 XT 20 GB Video Card ($689.99 @ Newegg)
Case: Fractal Design Pop Air RGB ATX Mid Tower Case ($59.99 @ B&H)
Power Supply: Thermaltake Toughpower GF1 (2024) 850 W 80+ Gold Certified Fully Modular ATX Power Supply ($94.99 @ Amazon)
Total: $1458.62
Generated by PCPartPicker 2024-08-07 13:40 EDT-0400
