I have old spare computer parts lying around, this includes a i7 9700k, 16 gb ram, motherboard, and ssds. I want to give these parts a purpose and set up a home nas/plex/game server if that's possible, games would include: minecraft, palworld, etc. I have a question on what other hardware/software i would need like if i need to buy a used graphics card or if anyone could include a list of requirements or a video link that would be helpful
https://linustechtips.com/topic/1578059-help-with-home-server/
Don't need a GPU; if you're doing any hardware transcoding, it will use the CPU's quicksync feature.
Software depends on what you're comfortable with. My server computer runs Truenas and then Plex/game servers in containers.
You can just as easily run windows for this, and it may be simpler that way
https://linustechtips.com/topic/1578059-help-with-home-server/#findComment-16480106
Okay thank you but I can run a plex/NAS +game servers on the system just fine without a gpu? Or can I not run those together?
https://linustechtips.com/topic/1578059-help-with-home-server/#findComment-16480147
Correct. You don’t need a GPU for a server unless you have a specific need for one. In your case you don’t.
Your 9700k has a GPU in it, which if you need to transcode for plex, that iGPU will handle just fine.
https://linustechtips.com/topic/1578059-help-with-home-server/#findComment-16480161
Okay so it turns out the motherboard I had for the 9700k doesnt have a video output on it so I can't use integrated graphics, which gpus should i be looking at for performance benefits for game server hosting? I was looking at getting a card like an rx 480 or gtx 1060 as i can buy those locally for ~50 dollars, what gpus would you recommend?
https://linustechtips.com/topic/1578059-help-with-home-server/#findComment-16481113
A game server will not use a GPU at all…
They make mobo’s for 9th gen that don’t have video out? I have not seen a consumer board without video out in quite a while, seeing as basically all chips have iGPU’s these days. Your sure it doesn’t have video out?
Id buy the cheapest GPU you can find, and I would go Nvidia for better driver support in server applications in general. A 1060 for 50 bucks would be fine.
https://linustechtips.com/topic/1578059-help-with-home-server/#findComment-16481127
Its a proprietary Asus ROG board from a prebuilt, I hadn't checked the io beforehand
https://linustechtips.com/topic/1578059-help-with-home-server/#findComment-16481130
Are you sure its a ROG board? Does it have a ROG BIOS?
I've never heard of Asus supplying proprietary Republic of Gamers boards to SIC's.
Is there a model number on it?
Just further to the discussion RE: iGPU;
- You only need a Video Out if you intend to plug in a monitor. If it still has the BIOS to initialize the GPU then it can still be used since I assume you're running the server headless. You can temporarily install a GPU for the OS install and/or configuration
- CoffeeLake CPU's are QuickSync v6...its probably not an issue; but just an FYI that it won't decode AV1 or HEVC 12-bit; so it will fall back into Software Decoding for those.
Desktop: Ryzen9 5950X | ASUS ROG Crosshair VIII Hero (Wifi) | EVGA RTX 3080Ti FTW3 | 32GB (2x16GB) Corsair Dominator Platinum RGB Pro 3600Mhz | EKWB EK-AIO 360D-RGB | EKWB EK-Vardar RGB Fans | 1TB Samsung 980 Pro, 4TB Samsung 980 Pro | Corsair 5000D Airflow | Corsair HX850 Platinum PSU | Asus ROG 42" OLED PG42UQ + LG 32" 32GK850G Monitor | Roccat Vulcan TKL Pro Keyboard | Logitech G Pro X Superlight  | MicroLab Solo 7C Speakers | Audio-Technica ATH-M50xBT2 LE Headphones | TC-Helicon GoXLR | Audio-Technica AT2035 | LTT Desk Mat | XBOX-X Controller | Windows 11 Pro
Server: Fractal Design Define R6 | Ryzen 3950x | ASRock X570 Taichi | Asus RTX 4060 Dual OC | 64GB (4x16GB) Corsair Vengeance LPX 3000Mhz | Corsair RM850v2 PSU | Fractal S36 Triple AIO + 4 Additional Venturi 120mm Fans | 8 x 20TB Seagate Exos X22 | 4 x 16TB Seagate Exos X18 | 3 x 2TB Samsung 970 Evo Plus NVMe | LSI 9211-8i HBA
NAS: Innovision 4U 24-bay chassis (12GB MiniHD SGIO Backplane) | Intel Core i9-10980xe | EVGA X299 FTW-K | EVGA RTX 2080Ti Super FTW3 | 128GB (8x16GB) Corsair Vengeance LPX 3200Mhz | DEEPCOOL PN1000M PSU| Noctua NH-D12L Chromax Black | 16 x 16TB Seagate Exos X18 | 2 x 2TB Samsung 990 Pro | 2 x 2TB Intel U.2 P4510 | LSI 9305-24i HBA
https://linustechtips.com/topic/1578059-help-with-home-server/#findComment-16481156
Yes it has the "asus rog gl12cx main board" printed on it; Yeah I'll probably end up buying a gtx 1060 just to have ease of use. I was planning to use the igpu just no motherboard output
https://linustechtips.com/topic/1578059-help-with-home-server/#findComment-16481196
Oh right its from an actual Asus system. Sorry misunderstood; thought it had come out of some boutique build by an SIC.
https://linustechtips.com/topic/1578059-help-with-home-server/#findComment-16481203
Also do you recommend any windows remote controlling software? I saw LTT used pulseway in the video Emily did but I don't think they're free anymore, any alternatives?
https://linustechtips.com/topic/1578059-help-with-home-server/#findComment-16481956
If you want to be able to access it from anywhere through a browser; check out Guacamole. It's a self hosted application and its a webserver that acts as an RDP Gateway to all your machines; so you can access more than 1 machine via it. It can be run via Docker; so you could install it in Docker for Windows with WSL2
https://linustechtips.com/topic/1578059-help-with-home-server/#findComment-16484719
