Help me :(
Go to solution Solved by Renegade042,
BIOS update using flashback.
Parts list:
amd ryzen 7 7800x3d
Samsung 980 pro 2tb
samsung 990 pro 4tb
Gskill trident z5 64gb
Gigabyte b650 gaming x ax
corsair rm850e
(no gpu, will be a 4080 super but its not in yet, just wanted a to get windows
Im a first time builder and have a problem, i put my computer together using linuses pov video and at first it didn’t display anything to my monitor but then after connecting to a tv it went to bios but was inconsistent, most times the diagnostic lights would get stuck on dram or vga and sometimes it would get to bios but couldn’t find my windows boot. Now after trying re-seat my ram and running it in single stick my status light alternates between vram and cpu almost like a boot loop, i cant get into the bios anymore and dont know what to do please help me! (i cant upload a video rn it just gives me an error)
https://linustechtips.com/topic/1578038-help-me/
21 minutes ago, Kgmonsterx said:
Parts list:
amd ryzen 7 7800x3d
Samsung 980 pro 2tb
samsung 990 pro 4tb
corsair rm850e
What rev. of the motherboard you got? Also check if ram is installed in slot A2 and B2
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
https://linustechtips.com/topic/1578038-help-me/#findComment-16479821
52 minutes ago, OddOod said:
Welcome to the forums!
I'd also recommend trying to reseat the CPU, but it's possible you have a DOA mobo
I would suggest it's only a microcode thing. Updating to F4 could solve the issue.
Gaming PC:
Linux PC:
https://linustechtips.com/topic/1578038-help-me/#findComment-16479922
yeah that worked, booted to bios first try and now i have windows installed, thanks!
https://linustechtips.com/topic/1578038-help-me/#findComment-16480569
