Odd LG OLED TV behavior (a *problem)
*update*
So it was apparently something to do with the VRR, I've had that PC off for a few weeks, though my friend used it the night before last, but I turned it on just now and it acted up. Even the OSD was going crazy but I was able to go through the menu and start tweaking things.... Turned off VRR and instantly fine. This was on DP.
So my overall assumption is that HDMI on my 3080 has pooped out and the LG doesn't like VRR. Those two combined quirks made life a living poop sandwich in trying to narrow it down.
Samsung is fine on 2080s HDMI and LG is fine on 3080 DP with VRR off. I'm glad I didn't swap gpu's back yet cause I would have never known exactly what was going on.
*edit: I hate to mark my own answer as the solution, but for anyone down the road that looks this up, they won't have to read my incoherent rambling and cut to the chase.
