hi all so i was wanting to build a all amd (ye sue me i a full team red i not scared to admit it) system but i not built a new system for a long time and things have changed a lot.
i appolagise in advanced for gramer and spelling issues due to dislexia
must be/have
  • i have a £750 budget
  • have 2.5gig nic
  • as much exspantion as possable
nice to have
  • multiple nic or a 10g nic
  • thunderbolt (ether built in or throu exspantion card not too bothered)
  • 6 or more sata onboard
  • multiple usb 3.2 2x2
  • high reliability/stability
  • as quiet as possable
  • onboard wifi
extra notes
  • willing to go to £1000
  • case, moniter, keyboard,mouse (well any peripharals not needed)
use caeses order of priority
  • CAD work
  • capter card recording (some time with streaming)
  • video editing (upto 4k aprox 90mps)
  • streaming (some time with with capter card recording)
  • gameing (nothing over 1440p (some times stream sometimes stream and record))
  • video transcodeing
https://linustechtips.com/topic/1577453-all-amd-system-build-help/
So will you be recording an external source like a console or are you streaming the games you are playing on the pc directly? Because for streaming content on the pc directly you do NOT need or even want a capture card.
Any reason for the multiple nics?
What is the EXACT usecase for thunderbolt? Desktop and laptop thunderbolt is VASTLY different so depending on usecase it may not work at all, other add in cards are needed or a better solution is available.
For a 750-1000£ budget the thunderbolt, high speed nic, many usb 40gb/s ports basically destroys the budget as that is for motherboards that will easily take up 1/3 of the budget if not more + add in cards needed.
This means that you wont end up with a good pc for the other usecases. So we need to know what exactly you need those usb 40gb/s ports for, thunderbolt, 10gb nic, 6 sata,... as that will also influence much of the other parts.
it will mostly be pc bast steaming but also useing capter card to use a a propper camera instead of a web cam
just to try get as much line speed as i ca but also split the load like saveing to nas on a high speed nic and use a lower speed nic for downloading and genral internet tasks
i wanting to keep the pc in a temp controled room and wil use a thuderbolt cable to dock to have perifarals separte
i am full open to sugestions
that why those are under the nice to have section as there not mandatory but would be nice to get
PCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (£174.99 @ AWD-IT)
CPU Cooler: Thermalright Assassin Spirit V2 66.17 CFM CPU Cooler  (£15.00 @ Computer Orbit)
Motherboard: ASRock B650M-HDV/M.2 Micro ATX AM5 Motherboard  (£119.99 @ Amazon UK)
Memory: TEAMGROUP T-Create Expert 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (£95.96 @ Amazon UK)
Storage: Kingston KC3000 2.048 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (£121.18 @ Amazon UK)
Video Card: Acer Nitro OC Radeon RX 7700 XT 12 GB Video Card  (£364.99 @ Currys PC World)
Case: Deepcool CC360 ARGB MicroATX Mini Tower Case  (£46.97 @ MoreCoCo)
Power Supply: Cooler Master V750 Gold i 750 W 80+ Gold Certified Fully Modular ATX Power Supply  (£89.99 @ Scan.co.uk)
Total: £1029.07
Generated by PCPartPicker 2024-07-24 15:33 BST+0100
Cheaping out a bit takes you under £1000. Not sure if worth it though.
Storage: Crucial P3 Plus 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (£99.98 @ Scan.co.uk)
Total: £992.87
Generated by PCPartPicker 2024-07-24 16:33 BST+0100
What camera? A lot have video capture over usb function built in no need for a dedicated card.
Windows doesnt really do that. This is adding A LOT more complexity for almost no benefit if it can even work.
This will cost FAR more than the whole pc. Those docks, long range thunderbolt and all that cost A LOT of money. The far cheaper and also usually more stable way is to just run the needed display cable(s) and a usb cable for peripherals.
Genuinly one of those thunderbolt fiber things is 500£+ for a older unit.
@Jeppesfirst build is a good system to go with.
Id say start with that, start yout hobbies and see if streaming catches on before spending too much.
