Should I get the window side panel version, or will that defeat the whole silent purpose. I just think that with all the cash I'm putting into it I might as well show off a little bit, but if having the window panel will make it as loud as other cases, I might aswell get a cheaper case. Thanks
https://linustechtips.com/topic/157701-define-r4-windowed-side-panel/
i have it and it is still silent as long as you don't run all of your fans at full speed
Christian and Proud of it
Please read the CoC        My Build Log
