27 minutes ago, THEGOLDNINJA1 said:
I installed core control but it’s not showing up in the software. do you think i installed the drivers wrong?
I had to do the advanced options command to edit Grub (which depends on the distro you're using)  for some stuff to show up. But I'm on AMD so I'm honestly not sure how well it does work with Arc if at all.
