Temps While Folding
Go to solution Solved by WhatTheQuack,
It will shorten the lifespan of the components if they run at those temps for a long tome, but not by much Those temps are perfectly normal, and below the max temps for a GPU and CPU. (85 degrees for a CPU, and 105 degrees for a GPU ~ correct me if I'm wrong)
Personally I would not feel comfortable folding at those temps 24/7, so I would give your PC a rest at least for a good 4-5 hours per day
My GPU temps on my reference 650 ti boost while folding get up to 71C. My CPU tends to hang around 50C. Am i safe to fold for extended periods of time with those temps?
CPU AMD A10-5800k  GPU GTX 960 Gigabyte G1 Motherboard Asrock fm2a75m-dgs Ram G.skill 8gigs ddr3 PSU Corsair HX650 HDD Two 1TB Hitachi 7200 rpm Case Zalman z11
Keyboard CM Storm Quickfire TK with chery mx reds Mouse Logitech m500 Headset Logitech g430 Laptop Lenovo u310 touch Phone HTC one
https://linustechtips.com/topic/157484-temps-while-folding/
You should be fine. Just don't be TOO surprised if one of the two dies in ~2 years if you fold on it 24/7
I mostly fold during the day while at work. I am planning on some upgrades in a few months anyway
https://linustechtips.com/topic/157484-temps-while-folding/#findComment-2098780
My PC:
4670k      GTX 760 ACX      CoolerMaster Hyper 412s      Fractal Design Node 804      G1 Sniper M5      Corsair RM 650      WD Red 1TB     Samsung 840 Evo 120GB
https://linustechtips.com/topic/157484-temps-while-folding/#findComment-2098793
That's pretty much true for all Intel chips.
AMD on the other hand... My laptop's CPU's TJMAX is 115c... so yea...
Some chips you shouldn't run at more than 65c (I don't remember the names of those though)
https://linustechtips.com/topic/157484-temps-while-folding/#findComment-2098799
Intel says they can max out at 110C but I would never let CPU near that temp.
https://linustechtips.com/topic/157484-temps-while-folding/#findComment-2098854
not for amd cpus
My Setup :P
Skylake: I7-6700|MSI B150 GAMING M3|16GB GSKILL RIPJAWS V|R9 280X (WILL BE 1070)|CRUCIAL MX300 + WD BLACK 1TB
https://linustechtips.com/topic/157484-temps-while-folding/#findComment-2098898
my cpu temp goes to 60c will it shorten my lifespan for much?
CPU: Intel core i7-4770 --- CPU Cooler: Corsair H105 --- GPU: Asus Geforce GTX 970 Strix --- MB: Asus Maximus VI Hero --- RAM: Corsair Vengeance Pro 16GB
Case: Corsair Obsidian 750D --- PSU: Corsair AX860i --- SSD: Seagate 120GB --- HDD: Seagate 2TB + Toshiba 1TB --- ODD: Asus External DVD-R
Keyboard: Razer Blackwidow 2013 Ultimate --- Mouse: Logitech G602 --- Mousepad: Corsair Vengeance MM600 --- Monitor: LG 29UM65
https://linustechtips.com/topic/157484-temps-while-folding/#findComment-2101598
My fx-6300.
Unfort, it gets to 70 degrees when folding for me, and stock cooler fan got up to 5300 RPM...
https://linustechtips.com/topic/157484-temps-while-folding/#findComment-2101683
not sure what the best answer guy is talking about, 50 degrees Celsius on the cpu is very low and PERFECTLY fine, just fold away, there's no reason to give it "breaks" from folding, computers don't really work like that  :P, as for the gpu, yeah that's abit on the higher side but i wouldn't worry much about that either, by default folding will decrease lifespan a wee bit because it's putting all your hardware at 100% load.
https://linustechtips.com/topic/157484-temps-while-folding/#findComment-2103753
thats fine mate
when im folding/mining i get gpu of 75'c and cpu of 55'c
the thermal limit for most cpu's is 62'c
and gpu's can run up to 95'c without much problems
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
  • Mouse
  • Sound
  • Operating System
https://linustechtips.com/topic/157484-temps-while-folding/#findComment-2103770
