cpu CPU cooling idea
4 minutes ago, TatamiMatt said:Because, mainly, this will keep the cpu cool, for all of x amount of time until the liquid boils, or becomes hotter than the CPU and turns into an insulator, cpu overheats thermal throttles and the cooler is made redundant. This is essentially, what a water cooler does, except, regardless of whether the water block is direct die or just on the IHS, it moves the liquid around a ton and to a place where is can cool itself off easily
Think of a kettle, the water is the cooling liquid and the heater at the bottom is the cpu, the kettle gets much hotter than it does cold until the water boils
Yeah but what if the water is actually flowing over the die itself just like with a normal liquid loop and not just sitting there.
I still think a cold plate is more efficient due to larger surface area the water will hit.
