Budget (including currency): 4000-5000 $USD
Country: USA
Games, programs or workloads that it will be used for: Cod, GTA, Cyberpunk, Elden Ring, Red Dead Redemption 2 & other Triple A single player story driven titles as well as for production such as video editing with adobe software
Other details: I do want an RTX4090 included & prefer an amd ryzen 7 or above for cpu, the extras such as RGB isn't a necessity I mainly want what's going to allow me to run what i need to run at the best bang for my buck like I don't need the most expensive part for everything but I do want the things that are going to give me best overall quality. (IF IT'S SOMETHING THAT WON'T MAKE A HUGE DIFFERENCE THEN I'D PREFER THE OPTION THAT'LL GIVE ME THE BEST BANG FOR MY BUCK I KNOW THE BUDGET IS PRETTY EXPENSIVE BUT I DON'T WANT THE MOST EXPENSIVE PARTS JUST BECAUSE IF I WON'T REALLY HAVE A USE FOR IT OR IT'S NOT REALLY NECESSARY) Thank You for any help!
https://linustechtips.com/topic/1573101-build-help/
If that's the case, then you only really need about half of this budget for a top of the line gaming system?
https://pcpartpicker.com/list/tpFw4M
The only thing that I might change in it is the SSD and CPU depending on the capacity you need and what the video editing actually requires. 2TB should be fine, and realistically you're not going to notice a faster drive, so I'd only change that if you want 4TB (given your budget, you could probably afford that if you wanted), and as for the video editing are we talking steam highlight clips or 8K Raw with a lot of effects?
https://linustechtips.com/topic/1573101-build-help/#findComment-16434307
Country: USA
How many screens?
Have you tried turning it off and on again?
https://linustechtips.com/topic/1573101-build-help/#findComment-16434310
So, this would be a core build:
PCPartPicker Part List
CPU: AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor  ($339.99 @ Amazon)
CPU Cooler: Thermalright Peerless Assassin 120 SE 66.17 CFM CPU Cooler  ($33.90 @ Amazon)
Motherboard: Gigabyte B650 GAMING X AX V2 ATX AM5 Motherboard  ($179.00 @ Amazon)
Memory: *Silicon Power XPOWER Zenith Gaming 64 GB (2 x 32 GB) DDR5-6000 CL30 Memory  ($181.99 @ Newegg Sellers)
Storage: Acer Predator GM7000 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($134.99 @ Amazon)
Video Card: *PNY VERTO GeForce RTX 4090 24 GB Video Card  ($1719.99 @ Amazon)
Case: Corsair 4000D Airflow ATX Mid Tower Case  ($104.99 @ Amazon)
Power Supply: Corsair RM1000e (2023) 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  ($179.99 @ Amazon)
Total: $2874.84
Generated by PCPartPicker 2024-06-09 18:22 EDT-0400
Which then you could expand with several choices,
first would be CPU, you could get the higher class x3D chips, they have one small downside and that's that only half of their CPU cores are attached to the 3D cache, this may or may not cause slight fluctuations in fps and other things, manageable though, with few tweaks and patience usable and use more cores, if you need them, you probably don't need that many cores, so probably stick with 7800x3D.
second you want bit more fans than what the case comes with, both for nice fresh air and for the exhaust of the hot air,
third you want more drives for your plentiful stuff, or just specific drive for your creative work that can handle more sustained performance and be better for smoother operation of the files and the apps if they're on them, not much improvement with gaming on that part but bit faster load times,
and that would look like this:
Storage: Acer Predator GM7000 4 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($274.99 @ Amazon)
Case Fan: ARCTIC P12 56.3 CFM 120 mm Fans 5-Pack  ($23.99 @ Amazon)
Total: $3173.82
Generated by PCPartPicker 2024-06-09 18:28 EDT-0400
current PC:
PC configs I used before:
https://linustechtips.com/topic/1573101-build-help/#findComment-16434312
Also consider Microcenter if it's located near you
current PC:
https://linustechtips.com/topic/1573101-build-help/#findComment-16434318
Honestly, you might want this MB, it's 50% for bragging rights because it's more expensive, but it also is on X670 chipset, which should have more PCIe lanes: (which is good especially if you're going to have more storage devices like M.2 SSDs and SATA drives, it is though bit premium extra, B650 is quite plentiful for best bang for the buck)
Motherboard: Gigabyte X670 GAMING X AX V2 ATX AM5 Motherboard  ($199.99 @ Amazon)
current PC:
https://linustechtips.com/topic/1573101-build-help/#findComment-16434322
Yeah i was thinking of going 4TB  & 8k Raw with effects
https://linustechtips.com/topic/1573101-build-help/#findComment-16434326
Country: USA
You don't need $5k for a top of the line PC.
My list - definitely not the best, check out the other replies as well. But it's pretty good.
CPU Cooler: NZXT Kraken Elite 360 RGB 78.02 CFM Liquid CPU Cooler  ($273.99 @ Amazon)
Motherboard: Gigabyte X670E AORUS PRO X ATX AM5 Motherboard  ($279.37 @ Amazon)
Memory: TEAMGROUP T-Force Delta RGB 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($106.99 @ Amazon)
Storage: Crucial P3 Plus 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($122.48 @ Adorama)
Video Card: Asus ROG STRIX GAMING OC GeForce RTX 4090 24 GB Video Card  ($2079.99 @ B&H)
Case: Lian Li O11 Vision ATX Mid Tower Case  ($139.99 @ Adorama)
Custom: AsiaHorse 18AWG PSU Cable Extension Sleeved Custom Mod GPU PC Audio Video Power Supply Soft Braided Cables with Two Color Comb Kit 24P/8P to 6+2P/ 8P to 4+4P 30CM  ($19.89 @ Amazon)
Total: $3542.68
Generated by PCPartPicker 2024-06-09 18:40 EDT-0400
hi
https://linustechtips.com/topic/1573101-build-help/#findComment-16434328
Lol the build you made is well under the budget so getting that one definitely won't hurt
https://linustechtips.com/topic/1573101-build-help/#findComment-16434329
it's not necessary though, and it uses some whistles already, though not much, the 2TB SSD could be @RONOTHAN##'s WD Blue SN580 and you wouldn't notice a difference in games, because SSDs don't do much in games, they just load and store them.
B650 has 36 PCIe lanes, GPU uses 16 and M.2 storage 4, which is still under 36 when you use all 3 M.2 slots my MB has
current PC:
https://linustechtips.com/topic/1573101-build-help/#findComment-16434332
Alright, let's see where we're paying extra $ for the brand:
150$+
90$+
better alternatives
300$ cheaper alternatives
nice case, not sure if it comes with fans
current PC:
https://linustechtips.com/topic/1573101-build-help/#findComment-16434334
Total: $3542.68
Lol i'm now seeing that and happy because that'll give me even more to invest in peripherals! thanks for all the help it's much appreciated.
https://linustechtips.com/topic/1573101-build-help/#findComment-16434336
10 minutes ago, tryagaintony said:
8k Raw with effects
Alright, then swap out the 7800X3D for a 7950X, 7950X3D, or soon to be released 9950X. The 7950X is faster in production applications, the 7950X3D is faster in games but the scheduler for it is weird and needs to be supervised for the best performance, and the 9950X should hopefully be the best of both worlds (no scheduler and about 15% faster than the 7950X) but for an extra ~$200.
Purely in games, the 7800X3D is the better pick compared to all of these CPUs, hence why I was asking as you only really want to go Ryzen 9 if you actually need the cores.
https://linustechtips.com/topic/1573101-build-help/#findComment-16434338
I didn't think of that, 7950x is probably better for gaming AND video editing/productivity
hi
https://linustechtips.com/topic/1573101-build-help/#findComment-16434341
his build is more expensive
current PC:
https://linustechtips.com/topic/1573101-build-help/#findComment-16434344
CPU: *Intel Core i7-13700K 3.4 GHz 16-Core Processor  ($329.99 @ Amazon)
CPU Cooler: *Deepcool LS720S ZERO DARK 85.85 CFM Liquid CPU Cooler  ($99.99 @ Amazon)
Motherboard: *MSI MAG Z790 TOMAHAWK WIFI ATX LGA1700 Motherboard  ($205.78 @ Amazon)
Memory: *Silicon Power Value Gaming 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($94.97 @ Amazon)
Storage: *Samsung 970 Evo Plus 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  ($103.90 @ Amazon)
Storage: *Samsung 990 Pro 4 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($319.99 @ Amazon)
Video Card: *Asus TUF GAMING OC GeForce RTX 4090 24 GB Video Card  ($1749.99 @ Newegg)
Case: *Lian Li LANCOOL 216 ATX Mid Tower Case  ($94.00 @ Newegg Sellers)
Power Supply: *be quiet! Pure Power 12 M 1200 W 80+ Gold Certified Fully Modular ATX Power Supply  ($146.90 @ Amazon)
Operating System: *Microsoft Windows 11 Home OEM - DVD 64-bit  ($119.99 @ Amazon)
Monitor: *Gigabyte GS27Q X 27.0" 2560 x 1440 250 Hz Monitor  ($279.99 @ Amazon)
Total: $3545.49
Generated by PCPartPicker 2024-06-09 19:09 EDT-0400
A better look at those components.
https://www.gigabyte.com/Monitor/GS27Q-X#kf
https://www.msi.com/Motherboard/MAG-Z790-TOMAHAWK-WIFI
https://www.intel.com/content/www/us/en/products/sku/230500/intel-core-i713700k-processor-30m-cache-up-to-5-40-ghz/specifications.html
https://www.deepcool.com/products/Cooling/cpuliquidcoolers/LS720S-ZERO-DARK-360mm-Pure-Performance-Liquid-Cooler-1700-AM5/2023/17571.shtml
https://www.bequiet.com/en/powersupply/4406
https://lian-li.com/product/lancool-216/
https://linustechtips.com/topic/1573101-build-help/#findComment-16434345
Just now, PowerPCFan said:
I guess we all assumed the main purpose was gaming, as you can see from the 7800X3D in these lists 😂
it's in the OP,  hidden:
I'd be more passionately open to what I'm going to do on a machine I'm spending 5000$ for, for example it's nice to know video editing, but video editing 1080p vs 8K is like difference between a candle and a Sun
current PC:
https://linustechtips.com/topic/1573101-build-help/#findComment-16434346
1 minute ago, Why_Me said:
500GB for Windows, 4TB for storage.
personally with decent budgets, I'd go for 1TB OS storage, not that 500GB isn't enough, but because there are certain things that love to use that drive, like apps that don't let you choose install location, AppData, Temp and other default folders
current PC:
https://linustechtips.com/topic/1573101-build-help/#findComment-16434348
I edited that message because I read it again and saw that lol
Yeah lol
hi
https://linustechtips.com/topic/1573101-build-help/#findComment-16434349
150$+
90$+
better alternatives
I guess I was just going for the top-of-the-line all-white parts since they have a $5000 budget, there are definitely cheaper alternatives
hi
https://linustechtips.com/topic/1573101-build-help/#findComment-16434353
150$+
90$+
better alternatives
bro forgot to mention the 1000w rme that is 30$ over a 1200w montech titan gold and 200w less than said titan gold
https://pcpartpicker.com/list/PmJFDZ
7900x3d + 64gb 6000c30 + 4090
7900x3d is cheaper than the 7800x3d for some reason and it has some extra cores albiet 2 less cache cores
if you wanna run dual gpu get the b650 proart, if you want tons of usb3 with a usb 4 port on the rear i/o + postcode + eclk if you wanna overclock the cache cores then theres the b650 taichi lite
ssd wise i just chose a normal high end gen4 but if you think youd benifit from a faster ssd the crucial t700 is 380$ and puts the overpriced 990 pro alongside all high end gen4s (including the one on this list) to shame, theres also the even faster t705 for 518$ but those are damn expensive
https://linustechtips.com/topic/1573101-build-help/#findComment-16434357
8k Video editing so would that change anything on the build that you made?
https://linustechtips.com/topic/1573101-build-help/#findComment-16434361
