My CPU is Ryzen 5 2400g and it's paired up with 10603gb asus OC edition. i have 16gb ddr4 3200mhz ram dual channel. my CPU is always under the base clock even though the temps are fine. also in Valorant, my fps dips a lot. is it just a case of bottleneck or is my CPU not performing as it should? I have never seen my CPU go to its boost clock. motherboard: bio star A320MH. I know the GPU is fine because my friend had this GPU before and had no fps issue.
https://linustechtips.com/topic/1572450-fps-issue-and-low-base-clock/
This may be caused by VRM throttling. Get HWinfo64 and check the VRM temperatures when under load.
Ryzen 7 5700X3D (CO -30) - AX370-Gaming 5 - 2x16GB @3600C18 - EVGA RTX 3070 8G XC3
[PBO2] CO -25/-25/-30/-30/-30/-30/-30/-30
[BIOS] Vsoc 1.1 / DRAM XMP
i5-6400 4.38GHz @1.36v (162.2 BCLK) - Z170M-Plus - 2x8GB @3244C16- Biostar RX 570 8G w/ MSI Armor cooler
[BIOS] BCLK: 162.2 (x27) / Vcore 1.35 / DRAM 3244 (XMP timings) / FCLK 1GHz (1622) / RebarUEFI patched
ROG G531GT : i7-9750H (uv) - GTX 1650 +700mem - 16+8GB @2666 - 1920x1080@145Hz (up to 172Hz) IPS panel
[Throttlestop] FIVR - Vcore -160 / Vcache -105 / iGPU+unslice -125 (IccMax 255)
i5-4690K + Z97-AR + Panram Blue DDR3 2800 2x4GB Lightsaber Blue
iMac 21.5" (late 2011) : i5-2400S - Samsung 4x4GB PC3-1333 - HD 6750M 512MB - cheap Winten SSD (MacOS High Sierra) - 1920x1080@60 LCD
Acer Z5610 "Theatre" Core 2 Quad Q9550 - 2x2GB PC3-1333 (Samsung) - 1920x1080@60Hz Touch LCD - great internal speakers
  • 3 weeks later...
