Is that the right battery for cmos?
Go to solution Solved by keskparane,
Typically yes. CR2032
If you're interested in a product please download and read the manual first.
Don't forget to tag or quote in your reply if you want me to know you've answered or have another question.
Well its a msi b760 wifi plus and I coulsnt find anything in the manual about cmos
CTRL F allows you to search the manual.
PG 40 tells you about CMOS
Appendix? IV Has the battery spec.
Thx alot man i tought i lost 4-500€ but now there its fixed and thx again + how do I like mark that u helped me / this forum is finished
There should be a button for that below each post. Click the one on @keskparane's post that helped you ("mark as answer").
The battery itself tells you what model it is, usually by the engraved markings or in some rare cases, stamped, on top.
How so?
Usually nothing else fits in a ce 2032 button cell slot
