Is this good? - be quiet! Silent Loop 2 120mm AiO for 7800X3D
Budget (including currency): cheap but exceptional good, lets say less than 200€
Country: Germany
Games, programs or workloads that it will be used for: Gaming, mostly games like Black Desert, Helldivers, current gen games and onwards.
Hey guys, i was wondering if the current AiO (Silent Loop 2 120mm - push-pull config) that I have is actually sufficient for my CPU (7800X3D).
Background is I dont know much about where the temperature should be/not be and since Summer is about to hit I wanna be careful.
I hit like 64°C~ under minimum load, 72-75°C while idle and at least 80-82°C while medium gaming (its a CPU heavy game tho, Black Desert) with a relatively high noise level and fans going on full power. I think i havnt seen it go higher than 85°C yet, havnt had a look on it the whole time tho. (Temperatures are from AIDA64)
My choice is very hard to make since i dont want pure performance but also something aesthethically pleasing if i had to upgrade.
During gaming, sub 85 degrees is a reasonable temp. Doesn't look like you have any cooling problems with this setup
Primary PC:
Country: Germany
120mm AIOs aren't great, thankfully the 7800X3D is so efficient that it stays relatively cool during gaming even with a 120mm AIO
If you want better temps and good looks then get an Arctic LF3 240mm and top mount it with the fans pushing air out of the radiator
Message me on discord (bread8669) for more help
Current parts list
CPU: R5 5600 CPU Cooler: Stock
Mobo: Asrock B550M-ITX/ac
RAM: Vengeance LPX 2x8GB 3200mhz Cl16
SSD: P5 Plus 500GB Secondary SSD: Kingston A400 960GB
GPU: MSI RTX 3060 Gaming X
Fans: 1x Noctua NF-P12 Redux, 1x Arctic P12, 1x Corsair LL120
PSU: NZXT SP-650M SFX-L PSU from H1
Monitor: Samsung WQHD 34 inch and 43 inch TV
Mouse: Logitech G203
Keyboard: Rii membrane keyboard
Damn this space can fit a 4090 (just kidding)
Country: Germany
Really cooler performance seems poor, as usual with 120mm AIO, but it's acceptable
A TR PA/PS 120 will do better.. Or get an AF III 240+ if you want an AIO
System : AMD R9  7950X3D CPU/ Asus ROG STRIX X670E-E board/ 2x32GB G-Skill Trident Z Neo 6000CL30 RAM ASUS TUF Gaming AMD Radeon RX 7900 XTX OC Edition GPU/ Phanteks P600S case /  Thermalright Peerless Assassin 120 cooler (with 2xArctic P12 Max fans) /  2TB WD SN850 NVme + 2TB Crucial T500  NVme  + 4TB Toshiba X300 HDD / Corsair RM850x PSU
Alienware AW3420DW 34" 120Hz 3440x1440p monitor / Logitech G915TKL keyboard (wireless) / Logitech G PRO X Superlight mouse / Audeze Maxwell headphones
Is the radiator part of intake or exhaust?
Feel free to ask any questions regarding my comments/build lists. I know a lot about PCs but not everything.
PC:
Ryzen 5 5600 |16GB DDR4 3200Mhz | B450 | GTX 1080 ti
PCs I used before:
Pentium G4500 | 4GB/8GB DDR4 2133Mhz | H110 | GTX 1050
Ryzen 3 1200 3,5Ghz / OC:4Ghz | 8GB DDR4 2133Mhz / 16GB 3200Mhz | B450 | GTX 1050
Ryzen 3 1200 3,5Ghz | 16GB 3200Mhz | B450 | GTX 1080 ti
Its sucks fresh air right from outside in a push/pull config
if you have PBO on I'm not surprised it jumps above 80C on a 120mm AIO
PC:
PCs I used before:
Where is it mounted?
I've been using computers since around 1978, started learning programming in 1980 on Apple IIs, started learning about hardware in 1990, ran a BBS from 1990-95, built my first Windows PC around 2000, taught myself malware removal starting in 2005 (also learned on Bleeping Computer), learned web dev starting in 2017, and I think I can fill a thimble with all that knowledge. 😉 I'm not an expert, which is why I keep investigating the answers that others give to try and improve my knowledge, so feel free to double-check the advice I give.
My phone's auto-correct is named Otto Rong.🤪😂
Its mounted at the top right. I have the H9 Flow Tower, which comes with 3 other intake fans and 1 outtake at the rear. I plan on upgrading a few more fans as well for better airflow
What's PBO?
just upgrade your AIO and you'll get much better temps
What's PBO?
Precision Boost Overdrive which is essentially an overclocking or under volting piece of software in the bios that clocks the CPU higher (but it is not manual overclocking)
Current parts list
I think i have everything overclockingwise disabled because I didnt want to risk my 120mm AiO not being able to handle the heat, so this temps should be under regular use, without overclocking
What's PBO?
I suggest mounting it on the side. You might be surprised.
Sorry for the late answer, i quite just dont get it really, can you throw me a bone here why that would be better?
Also, i noticed a lot of folks let their AiO push air out of the case instead of having it as a intake. My thought was that the radiator has the best source of cold air when it is a intake config as it is now, instead of having the heated air from inside the case go through the radiator.
Where to mount it is largely about the case. If you have the choice of top, side and front, to is the worst in most cases. If the airflow is less restricted on the side, that is the best place. If it's less restricted in the front, then there's the sweet spot.
One caveat on side mounting would be if there's a shunt to push air over the mobo instead of straight in. Generally, I suspect you'd have to remove that before mounting an AIO because most of the space is in front, not behind the shunt, so there's not enough space for an AIO otherwise.
If you front mount, intake is the best, but for side and top,  exhaust is best.
You can alter the "best" by doing things like removing filters and other barriers at exhaust points.
