Seagate IronWolf 12TB 230$ vs Seagate IronWolf Pro, 12 TB 240$ . worth it pro more 10$?
Solved by Eigenvektor,
Here's a comparison for the 4 TB model, so should be similar for the 12 TB one:
https://www.minitool.com/backup-tips/ironwolf-vs-ironwolf-pro.html
If the difference is only $10, I see no real downside to going with the Pro
johnny45 ·
Posted in Linux, macOS and Everything Not-Windows0 -
DJpanda808 ·
Posted in Displays1 -
JakubR8 ·
Posted in Power Supplies8 -
AccordingOne ·
Posted in New Builds and Planning5 -
1
Plutous ·
Posted in General Discussion2 -
9
5
2
3
