bought a dell Optiplex 5050
core i3 7th gen
16 gigs of ram
windows 10 home
and 250 ssd
idk much about it but i know the motherboard model is a dell Oem i just want to know if i can install any type of gpu iam thinking of a evga nvidia geforce gtx 1060 6gb but iam not sure and plss tell me if i could upgrade anything but keep in mind iam on a budget
https://linustechtips.com/topic/1567873-will-it-work/
Any reasonably modern motherboard can accept any reasonably modern PCIe GPU.
Issue with prebuilts is more commonly the powersupply and lack of cables.
And that budget would be?
https://linustechtips.com/topic/1567873-will-it-work/#findComment-16389635
core i3 7th gen
16 gigs of ram
windows 10 home
and 250 ssd
Another guy falling in the Dell Optitrap... 😞
Look at the PSU, 240W or so, there should not be any Pcie cable  to plug in a GPU, so you can  only use  crappy  GPU that only needs PCie slot power  : 3050,  1650,  6400XT...
https://linustechtips.com/topic/1567873-will-it-work/#findComment-16389637
5 minutes ago, modern_officer said:
idk just looking for a gpu under $500
Genuinly just buy a used gaming desktop.
500$ is plenty good to get a GOOD gaming pc used.
This optiplex is going to be TERRIBLE as it has a super slow old i3 its never going to be good for gaming eith that and the replacement i7's for that gen are stupud expensive for something that gets its ass handed to it by todays low end cpu's.
Return this box or sell it and make a build your own post
This is a moneysink that will cost you more to get a crappy pc than just start over.
https://linustechtips.com/topic/1567873-will-it-work/#findComment-16389645
its not for gaming iam using more for work and some adobe editers
https://linustechtips.com/topic/1567873-will-it-work/#findComment-16389658
I hope you got that system for super cheap, because a 2 core i3 is weak by today's standards.
Gaming With a 4:3 CRT
System specs below
CPU: AMD Ryzen 7 5700X with a Noctua NH-U9S cooler
Motherboard: Gigabyte B450 Aorus M (Because it was cheap)
RAM: 32GB (4 x 8GB) Corsair Vengance LPX 3200Mhz CL16
GPU: EVGA GTX 980 Ti SC Blower Card
HDD: 7200RPM TOSHIBA DT01ACA100 1TB, External HDD: 5400RPM 2TB WD My Passport
SSD: 1tb Samsung 970 evo m.2 nvme
PSU: Corsair CX650M
Displays: ViewSonic VA2012WB LCD 1680x1050p @ 75Hz
Gateway VX920 CRT: 1600x1200@75Hz, 1200x900@100Hz, 960x720@125Hz, 800x600@140Hz
Gateway VX900 CRT: 1600x1200@75Hz, 1200x900@100Hz, 960x720@120Hz (Can be pushed to 175Hz)
Keyboard: Thermaltake eSPORTS MEKA PRO with Cherry MX Red switches
https://linustechtips.com/topic/1567873-will-it-work/#findComment-16389706
It's bad for everything, you can get a better rig for $500
https://linustechtips.com/topic/1567873-will-it-work/#findComment-16389718
Oh geez this pc is gonna be even worse then.
Hope this was the 50$ it was worth because that i3 is just not gonna cut it for photoshop and the like. It will be slow.
Adding a gpu won't do much if anything here.
I recommend you put the 500$ to a whole different pc because this is not the one for you
https://linustechtips.com/topic/1567873-will-it-work/#findComment-16389910
