What are the best 140mm fans? For intake.
Akumatie
I'm looking to get 2 140mm fans for intake on my Fractal North case
Currently I am just using the stock fans as intake and for exhaust I've got 3 noctua nf-a12x25
I like to run my fans at a constant speed at around 1200rpm, don't want humming or weird noises
Don't care about pricing I just want the best noise to performance.
BQ Silent Wings Pro 140mm, best at least until Noctua does a new 140mm fan
System : AMD R9 5900X / Gigabyte X570 AORUS PRO/ 2x16GB Corsair Vengeance 3600CL18 ASUS TUF Gaming AMD Radeon RX 7900 XTX OC Edition GPU/ Phanteks P600S case /  Eisbaer 280mm AIO (with 2xArctic P14 fans) / 2TB Crucial T500  NVme + 2TB WD SN850 NVme + 4TB Toshiba X300 HDD drives/ Corsair RM850x PSU/  Alienware AW3420DW 34" 120Hz 3440x1440p monitor / Logitech G915TKL keyboard (wireless) / Logitech G PRO X Superlight mouse / Audeze Maxwell headphones
You have issue with the stock fans in the North?  Mine are great, but I'm older and my hearing isn't what it once was I guess.
Onyx AMD Ryzen 7 7800x3d / MSI 6900xt Gaming X Trio / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 32GB / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
Emma : i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p
Steam Deck 512GB OLED
OnePlus:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
In my experience its the Noctua 120mm that are annoying.
Are you sure its not the exhaust fans making an annoying noise?
Router:  Intel N100 (pfSense) WiFi6: Zyxel NWA210AX (1.7Gbit peak at 160Mhz)
WiFi5: Ubiquiti NanoHD OpenWRT (~500Mbit at 80Mhz) Switches: Netgear MS510TXUP, MS510TXPP, GS110EMX
ISPs: Zen Full Fibre 900 (~930Mbit down, 115Mbit up) + Three 5G (~800Mbit down, 115Mbit up)
Had a look and they look really good, a couple of reviews say they are the best, I'll get them when they come back in stock on OverclcokersUK
The stock fans on the north a good but I can't really put them up over 800rpm without them making a good amount of noise while my noctua fans are near silent at 1200rpm, and I would think getting new fans like the Be quiet Pro 4 would push more air and be more quiet than the stock fans.
My noctua fans sound really good for me at least, I know people like and dislike different noise frequencies
I do run mine at 1200rpm, I do know if I bump them to 1500 they are quite deep but I'd rather have deep fans than fans that are high pitched
Its likely I never managed to hit the right RPM, as mine being on Linux machines is problematic as you can only control the fans in the BIOS.  I was just quite disappointed how quickly those Noctuas get noisy, especially compared to the 140mm ones.
The annoying thing with fans is trying to figure out which fans have the most airflow at tolerable noise levels, given at best you usually only have the min/max airflow on the data sheet.
Gotta admit I am impressed with the Be Quiet fans over the last few years.
There is no point in getting the bq SWP4 unless you have special needs. If it's just for case intake, get the Silent Wings 4, high- speed Edition of that's not too loud.
What dBA seems to be the limit for you?
I've been using computers since around 1978, started learning programming in 1980 on Apple IIs, started learning about hardware in 1990, ran a BBS from 1990-95, built my first Windows PC around 2000, taught myself malware removal starting in 2005 (also learned on Bleeping Computer), learned web dev starting in 2017, and I think I can fill a thimble with all that knowledge. 😉 I'm not an expert, which is why I keep investigating the answers that others give to try and improve my knowledge, so feel free to double-check the advice I give.
My phone's auto-correct is named Otto Rong.🤪😂
Yeah I would think getting the high speed version would be fine as I am going to be using 4 pin fan control, and I wouldn't even use the switch on the back of the pro version,
I have no idea of my dBA limit I don't have one of them fancy machines
Download a sound meter program, calibrate it in a very quiet place,  and then do some experimenting.
Just throw the premium fans to front and ditch the other ones. You dont need more than that if you run at moderately high speed  like 1200rpm. When you go 700-800rpm intake, you start to need an exhaust or two.
Moderately high=1200 rpm? You're joking, or you're sensitive to sound, right?
A lot of these guys are "sensitive" to sound.
Moving air also makes noise, there is no escape.
AMD R7 5800X3D | Thermalright Frost Commander 140, TY-143
Asus Crosshair VIII Dark Hero | 32GB G.Skill Trident Z @ 3733C14
Zotac 4070 Ti Trinity OC @ 3045/1495 | WD SN850, SN850X, SN770
Seasonic Vertex GX-1000 | Fractal Torrent Compact RGB, Many CFM's
If you already got 3 NF-A12x25, then why not just get 3 more as intake? Or take one of the exhaust fans and put in front with 2 additional for positive airflow.
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: G.Skill Aegis 2x16gb 3200 @3600mhz | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Red Devil RX 7900XT | Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: MP510 960gb and 860 Evo 500gb | Cooling: CPU: Noctua NH-D15 with one fan
FS in Denmark/EU:
Asus Dual GTX 1060 3GB. Used maximum 4 months total. Looks like new. Card never opened. Give me a price.
I'm confused by your math, doctor. 3 intake - dust filter/ radiator resistance != 3 exhaust fans - exhaust grill resistance. If all fans are the same, that generally means negative pressure AFAIK. Please explain.
I forgot to say that I have 2 of them fans on an AIO, the top of the case and no way I've going back to arctic fans rather go passive than hear them humming and ticking
