FTTP Speeds
1 hour ago, Falcon1986 said:What would be very helpful is a network diagram with make/model labels for all relevant hardware and how they're interconnected.
PL can be blamed for a lot of speed and latency issues. It's one piece of network technology that is plagued with problems. If you're using them, I assume you would have accepted these limitations.
So you have 2 routers connected to each other? This is the setup that your ISP put in your home?
Are these speed tests performed while connecting over WiFi? How far are you from the mesh node? My memory of house construction in the UK is that even internal walls are made of thick, solid brick. If the WiFi going through walls/floors when you're doing these speed tests?
The Whole Home WiFi does not appear to act as a router, it appears to be a WiFi mesh completely independent of your router.
Its a bit strange the setup doesn't say to disable WiFi in the router, given this leaves you with one Access Point not part of the mesh (the router) which makes the mesh network less effective.
If possible I'd try plugging a wired device that has a Gigabit port into the cable the disc is plugged into, just to confirm the cable is working okay. Being limited to just under 100Mbit is usually a cable/port issue causing a 100Mbit link instead of Gigabit.
