Not enough pcie connectors...
skayqz
if i have one 6+2 pcie connector can i "multiply it"?
I have a 550w psu.
I have a 550w psu.
Kinda depends on the GPU & PSU and what exactly you meant by "multiply it"
but generally not recommended.
Edited by Poinkachu
Refresh before you reply
What psu?
A 550w only having one is odd so that makes me concerend about the quality.
Also no you shouldn't. You'd be asking DOUBLE the power of the cable and they are NOT rated to do rhat. Thats usually how you kill your system
I have a 550w psu.
You mean by buying a splitter?  No, dont do that.
What specific power supply is it? If you're wanting to expand it to another 6+2 connector(so you would effectively have 300W of headroom to the graphics card), then no, but it depends on the card. If you want to turn the 6+2 connector into dual 6 pin connectors, that's fine, since the total amount of power will be 150W.
Additionally, if the power supply doesn't have enough connectors, you should probably upgrade it.
MSI MAG A550BN 80+ Bronze 550W
That power supply should have two of them, according to the specs.
Good, because its on its way to my home lol aswell as a 1080
What made you believe that it only had one?
Wrong description of the product
What store did you buy this from that gave the incorrect description?
Worth checking the manufacturer sites before you buy.  Careful buying from that seller in the future, wrong info is the mark of a shady seller.
Onyx AMD Ryzen 7 7800x3d / MSI 6900xt Gaming X Trio / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 32GB / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
Emma : i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p
Steam Deck 512GB OLED
OnePlus:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
