Is the k70 rgb pro hot-swappable?
I bought switches for a new k70 rgb pro and i cant find if its hot-swappable
The switches are not hot swap.
K70 RGB PRO is not hot-swappable.
| Remember to mark Solutions! | Quote Posts if you want a Reply! |
| Tell us everything! Budget? Currency? Country? Retailers? | Help us help You! |
-= Topic moved to Peripherals =-
Reputation is a Lifetime to create but seconds to destroy.
 CHRISTIAN MEMBER
