I have several questions about my AIO
7 minutes ago, Patrik Martin said:Thank you for these information!
It might be nice to plug it in down there but the cable doesn't go there from the back and I'm not sure from the front but even if it did it would be ugly.
A cable splitter would be fine.
But I don't know what it would work with, brand matter ?
I was also thinking about a fan controller. I heard that would be good too.
Would it work with the NZXT Grid+V3 ?
a cable splitter will have 2 or more cables for 4 pin PWM connectors, 1 will deliver rpm signal the rest will just take the power it gets..
a PWM 2 or 3 port splitter is a standard you can get any that says PWM splitter
you can get pwm extenders too.. or just a splitter with longer cables. .
more than 3 fans i would put on a PWM hub.. and get power directly from the PSU.
