Sick of loud fans
B16
I have some corsair LL120 rgb fans and they're so loud that it's driving me insane, my case is a 4000D so theyre not starved of airflow and I have custom fan curves set up to try and limit the absolute wailing that they do. Is there any actual good options for RGB fans that are quiet? Cost won't matter much as long as it's not truly ridiculous price.
Also small rant but the lighting on ever corsair fan I've ever seen is tragic, half the colours are just tinted white, awful.
P12 ARGBs. I have an LL120 and it's horrible for airflow. The noctua NF-P12S redux next to it is much better for airflow at the same fan speed
I have a P12 too (non Argb) and it's very quiet, nearly as good as Noctua's NFA-12s but it has a bit of motor noise at certain rpms, but definitely better than the ll120s. P12 ARGB should be the same in terms of fan speed, noise and airflow
I haven't got this on my LL120 (in fact the only reason I'm still using it) is the RGB lighting which looks good for me, though recently I had a bug which didn't allow me to pick any lighting so I just left it in my case with no rgb (which is the only reason I am actually using it since i have another NH-P12S redux just sitting around)
Are you using iCUE? when I was using it all was well, though now it's basically not working, try updating iCUE maybe
There's also the UNIFAN SL-INF which are very good for noise (close to the best on techpowerup's charts) and still somewhat decent for airflow
Though I think P12 ARGBs would be a better choice unless you like the look of the SL-INF
Lian Li Uni Fan SL-Infinity 61.3 CFM 120 mm Fans 3-Pack (UF-SLIN120-3B) - PCPartPicker
ARCTIC P12 PST A-RGB 0dB 48.8 CFM 120 mm Fans 3-Pack (ACFAN00232A) - PCPartPicker
There is also non ARGB if you want to go with that in which case the P28's from lian li would be my pick, they are slightly thicker than 25mm (they're 28mm) but they're not too loud, have good airflow and are cheaper than their competitor, the Phanteks T30 (which is marginally better but costs around $30 more for the three pack)
Lian Li UNI FAN P28 92 CFM 120 mm Fans 3-Pack (P28120-3B) - PCPartPicker
btw ignore the Seasonic magflow, thats the fan they were reviewing but it's not good value or even great for performance
Message me on discord (bread8669) for more help
Current parts list
CPU: R5 5600 CPU Cooler: Stock
Mobo: Asrock B550M-ITX/ac
RAM: Vengeance LPX 2x8GB 3200mhz Cl16
SSD: P5 Plus 500GB Secondary SSD: Kingston A400 960GB
GPU: MSI RTX 3060 Gaming X
Fans: 1x Noctua NF-P12 Redux, 1x Arctic P12, 1x Corsair LL120
PSU: NZXT SP-650M SFX-L PSU from H1
Monitor: Samsung WQHD 34 inch and 43 inch TV
Mouse: Logitech G203
Keyboard: Rii membrane keyboard
Damn this space can fit a 4090 (just kidding)
do they wail at very low like 20% fan speeds too?
Feel free to ask any questions regarding my comments/build lists. I know a lot about PCs but not everything.
PC:
Ryzen 5 5600 |16GB DDR4 3200Mhz | B450 | GTX 1080 ti
PCs I used before:
Pentium G4500 | 4GB/8GB DDR4 2133Mhz | H110 | GTX 1050
Ryzen 3 1200 3,5Ghz / OC:4Ghz | 8GB DDR4 2133Mhz / 16GB 3200Mhz | B450 | GTX 1050
Ryzen 3 1200 3,5Ghz | 16GB 3200Mhz | B450 | GTX 1080 ti
T30s are good fans, powered by Sunon.
Corsair is really just a fancier Thermaltake. Booo.
Why you are losing headers.. not sure. Don't hot plug.
AMD R7 5800X3D | Thermalright Aqua Elite 360, 3x TL-B12, 2x TL-K12
Asus Crosshair VIII Dark Hero | 32GB G.Skill Trident Z @ 3733C14
Zotac 4070 Ti Trinity OC @ 3045/1495 | WD SN850, SN850X
Seasonic Vertex GX-1000 | Fractal Torrent Compact, 2x TL-B14
6 hours ago, filpo said:
Noctua's NFA-12s
I think I'm gonna go for either these or NF-S12A, noise is my biggest issue now and these corsair fans are just too much. Also I'll look at the T30s, they look quite good from the charts.
Are you using iCUE?
Yeah I've got iCUE and it works fine it's just specifically the colours pink, purple and orange show incredibly poorly when applied no matter how i try to change it.
Thanks for the reply, really helped me out a lot. 🙂
No, at about 1000rpm+ they just suddenly ramp up in noise an unreasoable amount, from quiet to being able to hear them from outside my room. I'm beginning to think there's an issue with them.
They are expensive though, and they aren’t much better than the p12 ARGB. The noctuas also don’t have rgb
Current parts list
some fans whine they they change their speed, especially upwards or when they're just agressively going 20% faster or something
Arctic P12s can be quite quiet, if you run your case fans from Motherboard header you can control their speed, and let them stay quieter
PC:
PCs I used before:
