True or false - Does vertically mounted (bracket up) GPUs have cooling issues?
13 minutes ago, DeerDK said:Hi everyone.
I've been eyeing the Silverstone Alta G1M for some time but when I read some user reviews, some people mention that there is an inherent issue with GPUs being mounted vertically in pillar style cases, with the bracket up (the end the dport/hdmi cables are coming out of). Something about the pipes not being designed for it.
I tried researching the topic but had trouble finding anything specific, apart from older vids and articles touching on the general subject of vertical gpus and the issues connected to the being too close to the case side ect.
Does anyone know some solid research on this topic, or some hands on experience?
There's a few layers here:
The GPU cooler's orientation has no significant impact on cooling, although might be better since most GPUs will exhaust out the 'top' of the card. Flow through in a normal orientation being a comparable example to the 'top' exhaust if vertically mounted.
Heatpipes operate at saturation and use the difference in pressure between the heat source and heatsink ends to circulate fluid. Its not like the Icegiant Thermosiphon that does require a specific orientation. They're dependent on a difference in temperature to operate since that's what produces the work on the fluid.
The 'being too close to the side panel' is the major problem a lot of vertically mounted GPUs run into especially if they have tempered glass side panels. As long as that's not the case where the GPU is physically mounted optimally, then you're fine. The other related problem you could run into is with tall M.2 coolers or CPU coolers, if you're using an air cooler. Those could physically impede you from vertically mounting your GPU.
