Not sure if cooler will fit in case
16 minutes ago, ryanmate543 said:Looking at picking up a hyper 212 black edition from marketplace for $30 AUD, but concerns on whether or not it will fit in my case as the cooler height is 159mm and the case supports up to 160mm. I am also worried about the distance between the cooler and the ram sticks. Does anyone have any experience with this?
Case - https://au.pcpartpicker.com/product/wj4BD3/corsair-icue-220t-rgb-atx-mid-tower-case-cc-9011174-ww OR https://www.corsair.com/us/en/p/pc-cases/cc-9011174-ww/icue-220t-rgb-airflow-tempered-glass-mid-tower-smart-case-white-cc-9011174-ww#tab-techspecs
Motherboard - https://au.pcpartpicker.com/product/xcBzK8/gigabyte-b650m-gaming-wifi-micro-atx-am5-motherboard-b650m-gaming-wifi
There are plenty of builds with that same cooler and case combo so it should fit.
