How do i secure my external Hard Drive?
Solved by OhioYJ,
That's easiest, and best way honestly. I would recommend making two partitions. Make one that the is entirely encrypted. Then one that is not encrypted. This unencrypted on you can store things on, like veracrypt for example, and other useful utilities.
Veracrypt will work in Windows, Linux, and Mac, so from any OS. Also note, that Veracrypt has a portable version that does not need to be installed.
Other things parts of Veracrypt you may want to look into (hidden volumes, definitely):
This one you can read up on, but I wouldn't recommend, as if you lose your keyfile, you are screwed. You will not get your data back.
