HELP ME!!!
Go to solution Solved by haydenpk,
1 hour ago, SImoHayha said:
Well for future reference just post the PCpart link here...  https://pcpartpicker.com/list/HTnDyg
1500$ budget? Okay we can fix this..
adjusted some things around. Ram is just 32GB. That's the new standard right now. Weaker CPU, but that doesn't matter in most things, cosidered you have a beefy GPU. Cheaper Motherboard w/o Wifi but added a USB wifi stick dongle that works just fine.
Cheaper case because well saving more money and there are tons of great cases for 50-60$ range. You don't need a pack of fans, multiple testing has shown having at least one exhaust fan is more than enough. Cheaper Monitor still get 144HZ refresh rate + 1MS response time.  You could save further money by getting a cheaper KB/Mouse but IDK that's up to you.
PCPartPicker Part List: https://pcpartpicker.com/list/hKBKL9
CPU: Intel Core i3-12100F 3.3 GHz Quad-Core Processor  ($94.98 @ Amazon)
Motherboard: ASRock B760M-HDV/M.2 D4 Micro ATX LGA1700 Motherboard  ($89.99 @ Amazon)
Memory: Silicon Power GAMING 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  ($53.97 @ Amazon)
Storage: Leven JPS800 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($99.99 @ Amazon)
Video Card: MSI RTX 3060 Ventus 3X 12G OC GeForce RTX 3060 12GB 12 GB Video Card  ($299.99 @ B&H)
Case: Antec NX100 ATX Mid Tower Case  ($41.40 @ Amazon)
Power Supply: Corsair CX (2023) 750 W 80+ Bronze Certified ATX Power Supply  ($64.98 @ Amazon)
Operating System: Microsoft Windows 11 Home Retail - Download 64-bit  ($119.99 @ Newegg)
Wireless Network Adapter: TP-Link Archer T3U Plus 802.11a/b/g/n/ac USB Type-A Wi-Fi Adapter  ($19.97 @ Amazon)
Monitor: Samsung Odyssey G30A 27.0" 1920 x 1080 144 Hz Monitor  ($179.99 @ Amazon)
Keyboard: Razer Huntsman V2 RGB Wired Gaming Keyboard  ($109.99 @ Amazon)
Mouse: Razer Basilisk V3 Wired Optical Mouse  ($49.99 @ Target)
Headphones: Razer BlackShark V2 X 7.1 Channel  Headset  ($39.99 @ Amazon)
Speakers: Creative Labs Pebble 2.0 4.4 W Speakers  ($18.99 @ Lenovo)
Total: $1284.21
Generated by PCPartPicker 2024-03-24 17:31 EDT-0400
Thank you I adjusted it a little bit and I found out that for first time builders mini atx is hard to build in. I got an Intel cor i5 12600k, an msi mag bz60 motherboard with wifi, an nzxt h510 i atx mid tower case, and a thermal right frozen note argb aio. The final price is 1542.75$, with peripherals. I might adjust further because my budget was for the pc so I could technically make it 397.95 dollars better. Again thank you
1 hour ago, haydenpk said:
I am building a budget gaming pc for mainly gaming but a little bit of video editing and I have a budget of 1,500$ and I am over budget. Suggestions on how to lower it.
Don't get a 3060 for $1500
CPU: AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor  ($368.99 @ Newegg)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  ($35.90 @ Amazon)
Motherboard: *Gigabyte B650 EAGLE AX ATX AM5 Motherboard  ($159.99 @ Newegg)
Memory: *Silicon Power Value Gaming 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($94.97 @ Amazon)
Storage: *Leven JPS800 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($99.99 @ Amazon)
Video Card: *Sapphire PULSE Radeon RX 7800 XT 16 GB Video Card  ($489.99 @ Newegg)
Case: NZXT H6 Flow ATX Mid Tower Case  ($109.99 @ Amazon)
Power Supply: *Cooler Master MWE Gold 850 - V2 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($89.99 @ Amazon)
Total: $1569.80
Generated by PCPartPicker 2024-03-24 17:39 EDT-0400
you can get a key for like $20 on scdkey tho, if you do try this
Motherboard: *ASRock B650M-HDV/M.2 Micro ATX AM5 Motherboard  ($119.99 @ Amazon)
Storage: TEAMGROUP MP44L 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($64.98 @ Amazon)
Video Card: *ASRock Phantom Gaming OC Radeon RX 7900 XT 20 GB Video Card  ($699.99 @ Newegg)
Case: BGears b-Pellucid MicroATX Mini Tower Case  ($50.99 @ Amazon)
Total: $1525.80
Generated by PCPartPicker 2024-03-24 16:44 EDT-0400
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
https://linustechtips.com/topic/1564114-help-me/#findComment-16362109
Bit blurry so hard to see, but you've got a fan pack, right? You could get a case that includes most of the fans, e.g. Lian Li 216.
You could swap out the AIO cooler for a peerless assassin or phantom spirit.
Remove the 2x8GB kit, you can add more RAM in the future.
https://linustechtips.com/topic/1564114-help-me/#findComment-16362110
Hi, welcome to the forums. A few things...
1. Your post is going to get moved to the "new builds and planning" subforum.
2. Please make your thread titles descriptive, not just "help."
3. PCPartpicker allows you to share a link to a build list. Please use this instead of posting crappy photos of your dirty screen. Even a screenshot would be better than this.
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
https://linustechtips.com/topic/1564114-help-me/#findComment-16362115
Your pictures are far from good.
25 minutes ago, filpo said:
if you get a key for $20 (won't give you link where but others can) then try this
He might not understand that,
You meant a Windows key for $20 instead of $120
Edited by leclod
If you don't quote us, we won't know you answered
https://linustechtips.com/topic/1564114-help-me/#findComment-16362116
https://www.techpowerup.com/320708/keysoff-presents-spring-sale-on-genuine-software-up-to-62-off
CPU: *Intel Core i5-12600KF 3.7 GHz 10-Core Processor  ($149.99 @ Newegg)
CPU Cooler: *Thermalright Phantom Spirit 120 SE 66.17 CFM CPU Cooler  ($35.90 @ Amazon)
Motherboard: *ASRock Z690 Pro RS ATX LGA1700 Motherboard  ($119.99 @ Amazon)
Memory: *TEAMGROUP T-Force Vulcan Z 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  ($55.99 @ Amazon)
Storage: *Acer Predator GM7000 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($124.99 @ Amazon)
Video Card: *Gigabyte EAGLE OC GeForce RTX 4070 Ti SUPER 16 GB Video Card  ($799.99 @ Newegg)
Case: *MagniumGear Neo Air 2 ATX Mid Tower Case  ($69.99 @ Newegg)
Power Supply: *MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($89.99 @ Amazon)
Total: $1446.83
Generated by PCPartPicker 2024-03-24 17:17 EDT-0400
https://linustechtips.com/topic/1564114-help-me/#findComment-16362138
20 minutes ago, haydenpk said:
quote
Total: $1284.21
NEVER GIVE UP. NEVER STOP LEARNING. DONT LET THE PAST HURT YOU. YOU CAN DOOOOO IT
https://linustechtips.com/topic/1564114-help-me/#findComment-16362152
4 minutes ago, 8tg said:
OP had a retail key which is priced correctly.
That is an OEM key for more money than a retail key?
Please research how windows keys work before clicking the buttons on PCPartPicker.
OEM is 5 bucks more. what's the difference?
Total: £1040.95
https://linustechtips.com/topic/1564114-help-me/#findComment-16362153
Total: $1284.21
https://linustechtips.com/topic/1564114-help-me/#findComment-16362230
mini-atx is not the same as Micro ATX. Mini-atx difficulty is only if the case is also a mini-ATX. If you have a normal or microsize case then there really isn't a problem. But glad I helped.
https://linustechtips.com/topic/1564114-help-me/#findComment-16362232
Sorry I had an account on my school chromebook and also I was using sharpie to trace something on the screen (terrible idea) and it bleached on the screen. I will follow your advice though.
https://linustechtips.com/topic/1564114-help-me/#findComment-16362233
Here's a very solid gaming rig for ~$1500 that will still cope with video editing... can easily get it below $1500 with a slightly lower spec M.2 (e.g. the 2Tb WD SN580 will save ~$60).
CPU Cooler: Deepcool AK620 ZERO DARK 68.99 CFM CPU Cooler  ($62.99 @ Newegg)
Motherboard: ASRock B650M Pro RS Micro ATX AM5 Motherboard  ($134.99 @ Newegg)
Memory: G.Skill Flare X5 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($106.99 @ Amazon)
Storage: Samsung 980 Pro 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($166.99 @ Amazon)
Video Card: Asus DUAL GeForce RTX 4070 12 GB Video Card  ($529.99 @ B&H)
Case: Montech AIR 903 BASE ATX Mid Tower Case  ($65.00 @ B&H)
Power Supply: Cooler Master MWE Gold 850 - V2 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($89.99 @ Amazon)
Total: $1525.93
Generated by PCPartPicker 2024-03-25 09:05 EDT-0400
Main rig: Ryzen 7 7800X3D, RTX3080Ti FE, 32Gb Teamgroup Create-T DDR5-6000C30, AC Freezer3 280mm AIO, Asrock Steel Legend X670E, M.2 2Tb Samsung 990 Pro, M.2 1Tb WDSN550, SATA 8Tb WD80EFAX, Corsair HX850, LianLi O11 Air Mini + 3x NF-A14's, MSI MPG 271QRX (27"/1440P/360Hz), Gigabyte M27Q (27"/1440P/170Hz), Asus PA248 (24"/1200P/60Hz), G815 kbd, G Pro X Superlight 2, Audezee Maxwell.
Games room "TV rig": 5800X3D, AC Freezer2 280mm AIO, ASUS Prime B450M, RTX4080S w/iChill AIO, 32Gb TridentZ DDR4-3600C14, M.2 500Gb & 1Tb WDSN550, 8Tb WD80EFAX, BeQuiet Straight 1000W,  LianLi O11 Air Mini, LG G4 (55"/4K/120Hz), G815 kbd, G502 mouse, LG G1 Soundbar / Audezee Maxwell.
Lounge HTPC: Minisforum UM760 Slim, Ryzen 5 7640HS, 16Gb DDR5, 1Tb M.2, LG C2 (42"/4K/120Hz), Logitech Touch K400.
Laptop: LOQ16, RTX4060, 16Gb DDR5, 2x 2Tb SN990 M.2.
NAS: Synology 1812+, 3Gb RAM, 3x16Tb Seagate EXOS RAID5, 1Tb MX500 cache, 3x3Tb WDRED RAID6, 120Gb SSD cache.
https://linustechtips.com/topic/1564114-help-me/#findComment-16362636
