Computer worked fine for 2 months. This morning, no post, CPU and DRAM lights on. Reseated all ram sticks individually, no change. Reset CMOS with one ram stick in and worked until I added the second ram stick, no post again. Now both RAM sticks appear faulty as system still won't post.
is there a fix or is my only solution to buy new ram?
SPECS:
CPU: ryzen 5 7600
GPU: rx 6600
Mobo: Asrock 620m pro rs
RAM: Corsair Vengeance 2x 16gb 6000mhz
PSU: 550w
Note: I removed all ram sticks and I still got not post and the lights where still on. I’m unsure if should be like that or if I would get a post saying no ram
https://linustechtips.com/topic/1563954-cpu-and-dram-light-on/
Try reseating CPU?
https://linustechtips.com/topic/1563954-cpu-and-dram-light-on/#findComment-16360979
53 minutes ago, icabasicfr said:
I’ve done that and checking for bent pins but nothing happened
turn off, reset CMOS then see if it boots?
current PC:
PC configs I used before:
https://linustechtips.com/topic/1563954-cpu-and-dram-light-on/#findComment-16361027
