How to remove cpu psu cables from mobo
8 minutes ago, Fat Cat11997 said:
Option #1 :
Slide in a rubber band, tighten to make it press the lock to open. Grip the connector using finger or nail, wiggle it out.
Option #2 :
Same as above, change hand/nail with long nosed plier
Option #3 :
Just keep it in, plug another CPU power cable to the header beside it.
Featured Topics
Slamp ·
Posted in Troubleshooting0 -
1stef ·
Steiger2010 ·
Posted in Graphics Cards1 -
ABADDON Aamir ·
Posted in Displays1 -
1
1
PDifolco ·
Posted in Graphics Cards3 -
HARDWELL9191 ·
Posted in CPUs, Motherboards, and Memory6 -
ChrisLoudon ·
Posted in Laptops and Pre-Built Systems1 -
midix ·
Posted in CPUs, Motherboards, and Memory2
play_circle_filled
Latest From ShortCircuit:
Lian-Li, do this on all of your cases! - Lian-Li O11D x Lamborghini
