I need help with finding a "gaming tv"
justaguy961
I have a relatively old TCL 4k tv which is basically the Walmart special. I'm looking for something that could do nice 4k or 1440p 120hz. Maybe HRD10 that stuff would be nice as well.  I don't know much about TVs and don't fully know if an LCD display would be okay or should i pay more for OLED. I don't want to get "scammed" and overpay for a mid TV.
OLED is nice if you can afford it. Certainly not the budget option. Do check up on their HDR capability though. My B9 didn't have the strongest HDR implementation and I don't bother with it at all. I think they did improve it in later models.
Gaming system: R7 7800X3D, Asus ROG Strix B650E-F Gaming Wifi, Thermalright Phantom Spirit 120 SE ARGB, Corsair Vengeance 2x 32GB 6000C30, RTX 4070, MSI MPG A850G, Fractal Design North, Samsung 990 Pro 2TB, Acer Predator XB241YU 24" 1440p 144Hz G-Sync + HP LP2475w 24" 1200p 60Hz wide gamut
Productivity system: i9-7980XE, Asus X299 TUF mark 2, Noctua D15, 64GB ram (mixed), RTX 3070, NZXT E850, GameMax Abyss, Samsung 980 Pro 2TB, random 1080p + 720p displays.
The LG C-series OLED TVs are bascially as good as it gets for a gaming TV. So currently the C3, in a few months the C4 will probably also come out, meaning you'll either get a better TV for the same price or a discount on the last-gen C3.
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
9 hours ago, jaslion said:
Budget?
maybe like $600. I dont need like 65 or 70in im fine with 50 or 55
