Budget (including currency): 2.500 - 3.000 Euros
Country: Netherlands
Games, programs or workloads that it will be used for: Gimp, Inkscape, Lightburn, Corelldraw, Fotoshop, Davinci resolve pro (6k video), Blender
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc):  they want an AMD cpu and 2 storage drives I was tinking about 1 M.2 ssd of about 1 terabite and a second ssd of at least 2 terabite if budget allowes even more storage the budget also includes mouse en keyboard but not the display
https://linustechtips.com/topic/1562869-need-help-picking-parts/
500GB for your o/s, 4TB storage.
AMD
PCPartPicker Part List
CPU: *AMD Ryzen 9 7900X 4.7 GHz 12-Core Processor  (€381.90 @ Azerty)
CPU Cooler: *ARCTIC Liquid Freezer III 56.3 CFM Liquid CPU Cooler  (€98.50 @ Azerty)
Motherboard: *Gigabyte X670 GAMING X AX V2 ATX AM5 Motherboard  (€242.95 @ Azerty)
Memory: *Corsair Vengeance 64 GB (2 x 32 GB) DDR5-6000 CL30 Memory  (€244.99 @ Amazon Netherlands)
Storage: *Lexar NM710 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (€43.85 @ Azerty)
Storage: *Lexar NM790 4 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (€233.85 @ Azerty)
Video Card: *Gigabyte WINDFORCE OC GeForce RTX 4070 Ti SUPER 16 GB Video Card  (€899.00 @ Amazon Netherlands)
Case: *Lian Li LANCOOL 216 ATX Mid Tower Case  (€95.85 @ Azerty)
Power Supply: *MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (€127.00 @ Amazon Netherlands)
Total: €2367.89
Generated by PCPartPicker 2024-03-16 18:51 CET+0100
Intel
CPU: *Intel Core i7-14700 2.1 GHz 20-Core Processor  (€432.95 @ Megekko)
Motherboard: *Gigabyte Z790 GAMING X AX ATX LGA1700 Motherboard  (€232.95 @ Azerty)
Memory: *G.Skill Ripjaws S5 64 GB (2 x 32 GB) DDR5-6000 CL30 Memory  (€226.25 @ Azerty)
Total: €2390.20
Generated by PCPartPicker 2024-03-16 18:43 CET+0100
Hello... I have made you a Build List. I got you a Single 4TB M.2 Drive which you can Partition anyway you like while you Install Windows. I also added a Keyboard & Mouse that are very good. Since it looks like you will be doing lots of Content Creation I picked the ASUS ProArt X670E Motherboard that has lots of Inputs on the Back I/O and a ASUS ProArt RTX 4080 Super 16GB GPU. This Combo is Perfect for all your needs. I added some extra Fans for the Case, 2x 120mm Fans for the Top of the PSU Shroud and 1x 140mm Fan to replace the Fan in the Rear. The AIO will go on the Inside Top of the Case. The Motherboard has more than enough Fan Headers for all the Fans so a Hub is not needed. I also added 64GB of RAM, Most Creators use 32GB for Gaming and the other 32GB for Creation. You can do both at the same time.
Please let me know what you think and I will be happy to answer any of your questions.
I have been building PCs for over 30 years so if you have any questions please ask. For Future Communication I use Discord for much Faster Response Times as I have it open 24/7. I am also available if you need help before, during, or after the Build Process on Discord through Text,Voice, or Video Chat. I can be with you while you build your new PC if you need me to be. Here is my Discord: Wizardsnapper#2772
https://nl.pcpartpicker.com/list/3zDDN6
CPU: AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor  (€367.85 @ Megekko)
CPU Cooler: Thermalright Frozen Notte ARGB 72.37 CFM Liquid CPU Cooler  (€83.90 @ Amazon Netherlands)
Motherboard: Asus ProArt X670E-CREATOR WIFI ATX AM5 Motherboard  (€439.00 @ Alternate)
Memory: G.Skill Trident Z5 Neo RGB 64 GB (2 x 32 GB) DDR5-6000 CL30 Memory  (€249.84 @ Azerty)
Storage: Lexar NM790 4 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (€233.85 @ Azerty)
Video Card: Asus ProArt OC GeForce RTX 4080 SUPER 16 GB Video Card  (€1191.80 @ Amazon Netherlands)
Case: Montech AIR 903 MAX ATX Mid Tower Case  (€88.85 @ Megekko)
Power Supply: Asus TUF Gaming 1000G 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  (€156.88 @ Amazon Netherlands)
Case Fan: Montech RX120 59 CFM 120 mm Fan  (€9.90 @ Amazon Netherlands)
Case Fan: Montech RX 90.5 CFM 140 mm Fan  (€20.85 @ Megekko)
Keyboard: Logitech G413 SE Wired Gaming Keyboard  (€77.95 @ Azerty)
Mouse: Logitech G502 Hero Wired Optical Mouse  (€54.90 @ Megekko)
Total: €2985.47
