Load balancing speed conundrum
7 hours ago, Indian pc builder said:I have parental controls in the deco I need to keep, what if I put one of the routers into bridge mode? That way it’ll be good right?(can the Multi wan router be put into bridge mode)
If the TP-Link multi-WAN router has such a mode, that would be a silly mode to have. You'd essentially be turning it into a switch, unless it has the ability to keep all of it's advanced features (such as load balancing).
These multi-WAN routers are purpose-built for small business applications that have specific needs. There's no need to have "alternate modes".
But why don't you examine the router's interface yourself? I'm assuming you have one of TP-Link's multi-WAN routers.
This is where marrying home user functions and business functions don't always go hand in hand.
Deco is meant for home use. So no surprise that it comes with parental controls that can be managed in the app. Multi-WAN routers are intended for business or advanced home setups where you're likely to have other ways of content filtering and restrictions. In this specific situation, I couldn't find "parental controls" in the TP-Link emulator for the ER605.
If you need both dual-WAN and parental controls with what you have now, then I guess that justifies multiple layers of NAT. I suggest you try the configuration and see if there are any issues to be concerned about at all.
What I think you need here is a multi-WAN mesh home WiFi system. Unfortunately, I don't think TP-Link carries this kind of system. Even the new Archer BE800 with its dual 10Gb LAN/WAN ports will only use 1 for WAN. You'll more likely see these kind of features with Asus/AiMesh and Synology hardware.
7 hours ago, Indian pc builder said:also how do you find this stuff on YouTube? I just bet directed into a void of useless videos
I subscribe to that channel and recalled seeing that video.
