Hi all, i have,
Monitor: Alienware AW3225QF
Processor: AMD Ryzen 7 7800X3D
Motherboard: ASRock X670E
RAM: Corsair Dominator Platinum RGB 32GB DDR5-6000
GPU: MSI Ventus x3 4080
Case: Lian Li Lancool III RGB
Liquid Cooling: iCUE H150i Elite Capellix 360mm RGB Water Cooling Kit
Power Supply: EVGA Supernova 850 PSU
Can i get some help setting up the best setting for this new monitor. i am playing in 4k if that helps
https://linustechtips.com/topic/1562696-could-i-get-some-help/
3 minutes ago, Sir Judgementz said:
Hi all, i have,
You just have to plug the monitor in...Then you can tweak the colors/contrast etc, but that's personal taste, there's no "best setup"
Very nice rig btw 🙂!
https://linustechtips.com/topic/1562696-could-i-get-some-help/#findComment-16351923
10 minutes ago, Sir Judgementz said:
Hi all, i have,
You can go and download the "display driver" aka color profile. Here you can also update the firmware. https://www.dell.com/support/home/en-us/product-support/product/aw3225qf-monitor/drivers
Make sure the monitor is set to whatever you want. for example 240hz
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
https://linustechtips.com/topic/1562696-could-i-get-some-help/#findComment-16351926
If you never had a G-Sync monitor before, these settings should help you dial them in: G-SYNC 101: Optimal G-SYNC Settings & Conclusion | Blur Busters
Other than that, just pick whatever settings look best to you. "Best settings" don't really exist, what you mean is probably "most accurate" in which case use the out of the box settings, as this monitor already has very good color accuracity. Use Peak 1000 for the best HDR experience. For more Info on the monitor you can watch this video:
Also, you should probably disable Dolby Vision until Microsoft fixes the Windows implementation, as mentioned in the video.
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
https://linustechtips.com/topic/1562696-could-i-get-some-help/#findComment-16351929
Even with 1k dimming, HDR is still a fallacy. You're not going to watch HDR movie content on it, HDR gaming? Cookie cutter.
Just my 2c with my Sony VA Bravia TV, which btw is a much better panel than anything big & OLED.
I can't stand organic diodes murder my eyes on big displays. Will wait for micro LED.
https://linustechtips.com/topic/1562696-could-i-get-some-help/#findComment-16351941
Interesting comments.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose, Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1562696-could-i-get-some-help/#findComment-16352004
