Best fans
NotReak
I was thinking about buying a new case and fans for my build beacuse i'm planning on buying a triple fan graphics card which dosen t fit in my current case.
But i got stuck on trying to find some good ARGB fans for my system, the current options are:
Corsair ICUE AR120
Cooler Master MF120 Halo
Arctic BioniX P120
Im open to any other fan suggestions
but not too expensive since i am on a budget
Arctic is pretty much unbeatable if you want decent quality on a budget.
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
on a budget:
Arctic P12 PWM PST 120mm 5 packs are about 25$, and are great fans, esp for the pricetag.
